Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Ruffstuff's Ideal Chevy 63" Swap Kit
Old Apr 14, 2016 | 06:34 PM
Gravel Maker's Avatar
FormerVendor
Finally the full kit! Everything you need to fully put those wonderfully versatile 63" Chevy Springs under your rig. We have offered a couple of options so you can fully customize the way the springs are set up on your vehicle.
You can choose the right perch & ubolt size for whatever axle you have, and you get to choose the length of the shackle to fit your need (most common is 5").
This badass kit can be found by clicking below or on the picture above.
Leaf Spring Swap Kits - RuffStuff Specialties
Old Jun 8, 2016 | 02:33 PM
FormerVendor
Get yourself riding on 63" of comfort and flex!
Old Aug 26, 2016 | 02:27 PM
FormerVendor
Get this popular swap done the right way!
Old Sep 2, 2016 | 07:19 PM
FormerVendor
Comes with our strong and sleek Frenched Spring Hangers for the frame!
Old Sep 21, 2016 | 06:03 PM
FormerVendor
The only way to get it done right!
Old Oct 3, 2016 | 07:57 AM
FormerVendor
Everything you need to get 63s under your Toyota in style.
Old Oct 12, 2016 | 08:11 AM
FormerVendor
Build season is coming up...
Old Oct 31, 2016 | 10:36 AM
FormerVendor
Make your plan to fix or upgrade whatever you've broken recently and get it done!
Old Nov 7, 2016 | 07:34 AM
FormerVendor
The only way to properly fit the all-mighty Chevy 63" springs in a Toyota.
Old Nov 21, 2016 | 03:19 PM
FormerVendor
It is time to make the swap!
Old Nov 28, 2016 | 06:40 AM
FormerVendor
Get yourself riding on 63 inches of comfort and flexability!
Old Dec 13, 2016 | 12:51 PM
FormerVendor
Cut it, grind it weld it. Pretty simple, I don't see why you are being so lazy...
Old Feb 3, 2017 | 07:10 AM
FormerVendor
The comfort and flex that every Toyota needs!
Old Mar 27, 2017 | 10:51 AM
FormerVendor
Get your self riding on 63" of off road performance!
Old Jun 30, 2017 | 02:46 PM
FormerVendor
The best way to get a comfy and flexy ride!
Old Feb 10, 2018 | 08:16 AM
FormerVendor
Time to make it happen cap'n!
Old Apr 11, 2018 | 07:43 AM
FormerVendor
63" of comfort await you....
Old Jul 11, 2018 | 06:35 PM
FormerVendor
A move some comfortable, it almost should have been stock!
Old Jan 11, 2019 | 12:23 PM
FormerVendor
The best choice for crawling or cruising ;-)
