Ruffstuff's Ideal Chevy 63" Swap Kit
Finally the full kit! Everything you need to fully put those wonderfully versatile 63" Chevy Springs under your rig. We have offered a couple of options so you can fully customize the way the springs are set up on your vehicle.
You can choose the right perch & ubolt size for whatever axle you have, and you get to choose the length of the shackle to fit your need (most common is 5"). http://www.ruffstuffspecialties.com/...R1799-full.jpg This badass kit can be found by clicking below or on the picture above. Leaf Spring Swap Kits - RuffStuff Specialties |
Get yourself riding on 63" of comfort and flex!
Get this popular swap done the right way!
Comes with our strong and sleek Frenched Spring Hangers for the frame!
The only way to get it done right!
Everything you need to get 63s under your Toyota in style.
Build season is coming up...
Make your plan to fix or upgrade whatever you've broken recently and get it done!
The only way to properly fit the all-mighty Chevy 63" springs in a Toyota.
It is time to make the swap!
Get yourself riding on 63 inches of comfort and flexability!
Cut it, grind it weld it. Pretty simple, I don't see why you are being so lazy...
The comfort and flex that every Toyota needs!
Get your self riding on 63" of off road performance!
The best way to get a comfy and flexy ride!
Time to make it happen cap'n!
63" of comfort await you....
A move some comfortable, it almost should have been stock!
The best choice for crawling or cruising ;-)
