Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Poly Bushing Kits from Barnes 4wd!
Old Jul 7, 2016 | 04:29 PM
Barnes 4wd's Avatar
FormerVendor
Poly Bushings and Bushing Kits from Barnes 4WD
This is a great kit, made from 2" DOM with a ¼" wall and a high quality poly bushing inner sleeve bore is 9/16" or 5/8” which gives you a very thick wall thickness that will not become egg shaped with hard use. This combo is great for any application that you need to isolate vibrations. These can be used for motor mounts, cage mounts, transmission and transfer case cross members and many other applications. Our DOM Sleeve with Poly Bushing comes in two lengths. Like all of our products, they are made in the USA from USA steel.
This is what you need to make that crossmember bulletproof and still vibration dampening, it comes with everything and is made of 2.0" DOM with a .25" wall and .375 Tabs for frame mounting (we can replace with 1.75" or 2.0" Radius Tabs for tube mounting). It comes with 2 grade 8, 9/16" bolts with Lock nuts, 4 high quality Bushings, and an inner Sleeves Cadmium coated. They are 3" wide. Sold in pairs.
Our single poly bushing kit comes with two bushings and one inner sleeve. The inner sleeve has a bore of 9/16" or 5/8” which gives you a very thick wall thickness that will not become egg shaped with hard use. The bushings are designed to fit a 1.5" ID tube.
Click Here To View Our Poly Bushing Kits
Old Jul 15, 2016 | 08:56 AM
Barnes 4wd's Avatar
FormerVendor
Quality you can trust!
Old Jul 21, 2016 | 10:02 AM
Barnes 4wd's Avatar
FormerVendor
The weekend is right around the corner!
Old Jul 26, 2016 | 01:21 PM
Barnes 4wd's Avatar
FormerVendor
Build it right the first time!
Old Aug 8, 2016 | 07:55 AM
Barnes 4wd's Avatar
FormerVendor
Get your upgrades at affordable prices!
Old Aug 15, 2016 | 10:32 AM
Barnes 4wd's Avatar
FormerVendor
Hope everyone had a great weekend!
Old Aug 21, 2016 | 04:45 PM
Barnes 4wd's Avatar
FormerVendor
We love staying busy!
Old Aug 26, 2016 | 11:38 AM
Barnes 4wd's Avatar
FormerVendor
We hope everyone has an excellent weekend!
Old Sep 1, 2016 | 03:22 PM
Barnes 4wd's Avatar
FormerVendor
Build season is almost upon us!
Old Sep 13, 2016 | 04:07 PM
Barnes 4wd's Avatar
FormerVendor
Tuesday bump!
Old Sep 22, 2016 | 03:41 PM
Barnes 4wd's Avatar
FormerVendor
The weekend is almost here!
Old Sep 29, 2016 | 02:58 PM
Barnes 4wd's Avatar
FormerVendor
Have questions? Call us!
Old Oct 7, 2016 | 11:42 AM
Barnes 4wd's Avatar
FormerVendor
End of the week bump!
Old Oct 26, 2016 | 07:25 AM
Barnes 4wd's Avatar
FormerVendor
Midweek bump!
Old Nov 3, 2016 | 02:21 PM
Barnes 4wd's Avatar
FormerVendor
Don't worry, if you have questions, call us!
Old Nov 16, 2016 | 03:38 PM
Barnes 4wd's Avatar
FormerVendor
Midweek bump!
Tofer
Dec 11, 2015 03:48 PM
kryptik
Jul 12, 2005 10:39 PM
