Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Panhard Kits from Ruffstuff
Old Apr 19, 2016 | 09:37 AM
Gravel Maker's Avatar
FormerVendor
These are pretty straightforward and simple, all it takes is a quick look and you understand what you need to do and more importantly, what you need to order!
We start you with 54" of 1.5" x .25" wall DOM tubing, then we make you choose between an axle Centered or Offset Bracket, and finally you decide if it will mount on the frame Inside or Outside. Each of the Brackets give you 3 choices of mounting height.
It comes with a set of our 7/8" 4130 Cryo treated Heims with 9/16" Misalignment and Hex Head weld bungs. The Hex Head bungs give you very fine adjustment easily. We also include the Grade 8 bolts in the correct length so you don't have to spend your day searching for them.
Here are the Two Frame-Side brackets:
Inside:
Outside:
And then the two options for the Axle Side:
Centered:
And Offset:
Here is a link to see all the parts, and kits:
http://www.ruffstuffspecialties.com/...dtrackbar.html
Old Jun 22, 2016 | 02:43 PM
FormerVendor
Get your geometry just right!
Old Aug 17, 2016 | 11:38 AM
FormerVendor
thanks for the orders
Old Sep 19, 2016 | 01:38 PM
FormerVendor
Make your geometry happy!
Old Sep 29, 2016 | 03:50 PM
FormerVendor
If you've done, or are doing a 3 link, or 4 link, these should be on your to-do list.
Old Oct 20, 2016 | 08:34 AM
FormerVendor
Make it right, and it will treat you right on the road, and on the trail.
Old Nov 9, 2016 | 09:17 AM
FormerVendor
All the pieces you need to make your geometry work out...
Old Dec 4, 2016 | 11:23 AM
FormerVendor
Give me a hollar if you've got any questions about which one is right for you!
Old Feb 3, 2017 | 07:11 AM
FormerVendor
Geometry... it matters!
Old Mar 31, 2017 | 10:41 AM
FormerVendor
Overbuilt is the only way that we roll.
Gamma_Hugo
Mar 11, 2016 08:47 PM
medicmoose
Feb 14, 2016 09:05 AM
MudWaspSR5
Feb 9, 2016 11:28 AM
vikecowboy
Feb 9, 2016 07:31 AM
MudHippy
Feb 7, 2016 08:02 AM
