ZUK question
Old Dec 10, 2013 | 02:25 PM
87blyota's Avatar
ZUK question
I am planing on doing a slight lift to my 87 pickup my rear springs do not sag and i was wondering if i do the zuk mod will i gain lift or does it only work on trucks that are sagging?
Old Dec 10, 2013 | 02:46 PM
cman1's Avatar
yes.please do a search,lots of info on this.
Old Dec 10, 2013 | 02:50 PM
87blyota's Avatar
i did a search but only found information on vehicles with sagging springs so i figured id better ask
Old Dec 10, 2013 | 03:01 PM
Inferno451's Avatar
Lift varies widely depending upon springs used. On my 87' 4Runner I used 96' 4runner rear coils with 1.5 coils cut off and probably gained 2 inches over stock. It was sagging pretty good before. Using these coils gave me the height i wanted and NO modifications were necessary. Just jacked the 4runner up and used a broomstick to wedge them in place. Gained some axle wrap however.
Old Dec 10, 2013 | 03:55 PM
87blyota's Avatar
can anyone give a idea on what springs to use? i was thinking of using black magic 14'' 125#
Old Dec 10, 2013 | 04:14 PM
cman1's Avatar
i have 13" 100lb blackmagic coils in back,raised it 3".i wouldnt go any higher than a 100lb spring on a pickup.
Old Dec 10, 2013 | 04:21 PM
87blyota's Avatar
i tend to load my bed up quit often. 100# spring doing okay with hauling things? mostly i haul a dirtbike and scrap metal
Old Dec 10, 2013 | 05:41 PM
cman1's Avatar
i can fill my bed with a face cord of wood and it moves about 1/2 inch.
Old Dec 10, 2013 | 06:08 PM
87blyota's Avatar
alright sounds good looks like ill give the 13" 100lb spring a try
Old Dec 10, 2013 | 06:19 PM
Crapple21's Avatar
i used stock jeep tj rear springs on mine and i didnt have to cut or modify anything and gave me 2 inches of lift.
Old Dec 11, 2013 | 07:05 AM
highonpottery's Avatar
If you haul heavy loads regularly then you might want to think about the proper fix - and that's to outright replace those leaf springs. Or add leafs/change the pack, re arch, etc. sure the coils will help, but is really only intended as a temporary/immediate/bandaid fix for those who have saggy rear but don't really use the truck as a truck. Just sayin'
Old Dec 11, 2013 | 09:09 AM
87blyota's Avatar
so i am confused. my current springs do not sag. will adding coils do anything?
Old Dec 11, 2013 | 11:14 AM
the whole purpose of the "ZUK mod" is to remedy the common butt-sag that many older toyotas have, since the stock leafs wear out and thus sag after years of use. it's a cheap fix used as an alternative to outright replacing the leaf springs which cost significantly more money, and now both the coil and leaf springs "share" the load above -- think of it as adding load-leveling airbags to a leaf-spring setup since they go in the same location and act similarly.
actual height and change in ride quality will be entirely dependent on the type of coil spring you insert, and how worn out your leafs are. since you say your leafs don't sag, then if you were to add a coil that brings you to "stock height", then you will likely not see any change in height, but will find the rear slightly stiffer. at least this is my guess, I chose to outright replace my leaf springs with OME Dakar leafs because I knew they would not only cure the saggy-butt, but would lift the rear of my truck ~2" and still have proper arch in the leaf, also they will have more travel in these leafs for wheeling since there is no coil spring fighting the up-travel.
punks_is_4x4
Aug 21, 2015 01:35 PM
makemusic116
Aug 2, 2015 05:23 PM
Massmayhem247
Jul 18, 2015 05:46 AM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
