will an 84 22r carb work with an 87 22r
Old Oct 28, 2008 | 08:15 PM
AJHaley's Avatar
just got ahold of one and need to replace my old one, just seeing if it would work out the same
Old Oct 28, 2008 | 09:15 PM
4Crawler's Avatar
If it is set up the same, as in similar vacuum hose attachments and linkages, etc. then it would likely work. Those differences could be due to different emissions requirements between the 2 engines.
Old Oct 28, 2008 | 09:50 PM
drew303's Avatar
It's workable for sure. Even if the emission setups differ it's still possible. I've seen 3 different versions (I'm gonna guess their are even more variations!) of 22R carb setups and all having vastly different vacum systems. Ask tofer about his 2wd pickup, I think it was an 81... that thing was amazingly complicated comparing it to my 87 2wd Cali model.. Cali models I THOUGHT had the most emissions. His had far more hoses.
But regardless, with enough vac caps, you can make any carb work. The basics you need are the PCV and Vac Advance, most everything else can be capped.
Old Oct 31, 2008 | 02:17 PM
AJHaley's Avatar
it ended up working but i still had the same problem anyways so it was kind of a wast of time
ashersullivan88yota
Jan 18, 2022 05:37 PM
Colington
Mar 8, 2020 09:51 AM
jerusry
Oct 19, 2015 05:28 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Suprarossa
Jul 6, 2015 05:21 AM
