Where to Mount Custom Sliderz
Old Sep 22, 2003 | 07:07 PM
Scarbro22's Avatar
Im making some custom sliderz with a friend who will do most of the work and need to know if we need to bolt to the frame (1 i think) or 2 (location of original running board mount). I want to be able to support the vehicles weight on these and mounting location is key. I'm right in thinking there is no way on earth that the stock boards will support the vehicle's weight right?
Help me decide, post why, and please remeber i want bolt on. What bolts would you suggest and is drilling required? Thanks
Old Sep 22, 2003 | 07:27 PM
upndair's Avatar
You're right, the stock running boards will not support any weight. The sliderz should be bolted/mounted to the frame rails.
Three mounts is a minimum, but I'd suggest 4 if you plan on actually USING them...
Old Sep 23, 2003 | 10:16 AM
4Crawler's Avatar
Here's how mine are installed
justdifferentials
14
Jun 11, 2017 08:36 PM
justdifferentials
Sep 5, 2015 06:52 PM
pplusent
Sep 2, 2015 11:56 PM
Ryall
Sep 2, 2015 06:48 AM
