Where did you get your D ring shackles?
Old 10-26-2007, 11:05 PM
Drama Queen/Banned
paxil4x4's Avatar
I got my ARB mounted on my 85 truck along with the Hella 500's. I went looking for some D rings today and could find nothing in this town. What size and where did you other ARB owners get yours?
The install of this bumper was flawless, except for some reason my splash pan don't fit like the instructions said it would. I will fix that in the morning.
Old 10-26-2007, 11:45 PM
Fossilized
Staff
dropzone's Avatar
I used 3/4" Shackles (bolt diameter) similar to what Marlin, Trail Gear etc sell. I have had them for a long time though... Depending on your location you might be able to find them at a farm store...
Old 10-27-2007, 01:13 AM
Drama Queen/Banned
paxil4x4's Avatar
I went to Tractor Supply and they had nothing everything was too small. I'm going to try another place in the morning.
Old 10-27-2007, 02:59 AM
rocket's Avatar
I just bought a pair last week from this seller...
http://myworld.ebay.com/ebaymotors/streetlegalpro/
http://cgi.ebay.com/ebaymotors/3-4-R...QQcmdZViewItem
They were shipped fast and packaged like souvenirs. Very nice quality too.
Old 10-27-2007, 05:29 AM
Fossilized
Staff
dropzone's Avatar
That is a good price on those...I just bought a couple more to have in the Trekker...
Old 10-27-2007, 05:31 AM
waskillywabbit's Avatar
We have shackles if you cannot find them locally.
www.wabfab.org/products/recovery/recovery.htm
Old 10-27-2007, 08:56 AM
idayota's Avatar
a good farm store or tractor supply will usually have 'em.
Old 10-27-2007, 09:16 AM
olharleyman's Avatar
Not sure if you are looking for weld on or just the shackle but you might want to check out HARSHTERRAIN on e-bay they have some nice weld on d rings very good price.
Old 10-27-2007, 12:36 PM
MudHippy's Avatar
Ace/True Value has many sizes, bigger ones than you want even. Painted too.
Old 10-27-2007, 02:18 PM
Co-Founder/Administrator
Staff
Corey's Avatar
From the Big & Tall store
Old 10-27-2007, 02:25 PM
ydopen's Avatar
Try a 18 wheeler dealer or 18wheeler trailer dealer we just got some new ones for our lowboy and for our drillrig they even had the weld-on half moons to mount them
Old 10-27-2007, 05:48 PM
bigarms23's Avatar
you might find good ones for a cheap price through northern bell tool catalouge
Old 11-11-2007, 03:28 AM
rocket's Avatar
A little shackle tech:
The ones i bought were 3/4" ...the same and only ones that TG, MC and many others sell. Very common size but after receiving them, i got to thinking...
These shackles are BIG and heavy. They have a working load limit of 13,000+ lbs. which is basically 3x's the weight of a 3rd gen 4runner. So i continued researching a smaller and lighter option....
A few days later, the same ebay seller had different sized shackles listed. I ended up buying 4 more that were 5/8" with a working load limit of 9,000 lbs.
* The 'breaking strength' limit of any clevis shackle is normally rated 4-5 times GREATER than the 'working load' limit. Something to keep in mind.
If you care about added weight as much as i do, then 5/8" shackles might be a better choice.
Comparison picture... 5/8" on the left and 3/4" on the right:
Old 11-11-2007, 03:32 AM
Drama Queen/Banned
paxil4x4's Avatar
I sized them up and I need ones with 7/8 pins for the ARB.
Old 11-11-2007, 03:47 AM
rocket's Avatar
3/4" shackles have a 7/8" pin...the 5/8" shackles have a 3/4" pin. Small difference.
Old 11-11-2007, 05:37 AM
Talking
Just remember the weight of your vehicle is not the only factor in sizing a shackle and that all shackles are NOT rated in the same manner. Some things to consider:
- weight of vehicle needing a tow
- condition of vehicle needing a tow - i.e., stuck in mud
- impact factor from driver error - i.e., jerking on shackle (1 to 3)
- pull rating on winch (if using one)
- angle of pull, force vectors
- room left in the shackle to run cable/rope/strap through it once attached
Add some of those loadings to your shackle mulitiplied by an impact factor and you run out of loading in a hurry.
IMO, with a shackle, use the biggest one that will fit.
Old 11-11-2007, 06:08 AM
redvette's Avatar
Industrial wire rope companies have them. I get them in town for 12.95 for a 5/8in shackle.
Old 11-11-2007, 06:18 AM
bballchrism's Avatar
i got mine from here http://www.wheelersoffroad.com/tacotowstrap.htm
Old 11-13-2007, 08:07 AM
ninjarunner's Avatar
where i live there is a store called Cal-Ranch. they carry every size shackle you can think of
Old 11-13-2007, 08:43 AM
jjrgr21's Avatar
look up fastenal, there are several across the country.
Quick Reply: Where did you get your D ring shackles?
