What Lights to use?
Old Jun 17, 2009 | 08:21 AM
xalier's Avatar
What Lights to use?
I got a 90 p/u and i just recently got a double roll bar and I was wanting to mount some lights on top and I was curious what size you guys have been mounting on top, watts, brand, where ya got them ect... I was thinking about putting 4 on it... Does anyone make some GOOD LED or HID kits that are really bright and dont take alot of amps to run? Any info is appreciated..
Old Jun 17, 2009 | 08:34 AM
Tofer's Avatar
Sponsor
"GOOD LED or HID's" will cost you $$$$ if you have the cash moneyz look at http://www.visionxoffroad.com/
otherwise look into some Hella's or KC's
Old Jun 17, 2009 | 10:17 AM
elblako91's Avatar
I got some Hellas. Look Here.
Old Jun 17, 2009 | 03:38 PM
suncomb1's Avatar
I run 4-KC 6" SS Daylighters, 150 Watt each on the Rollbar, 2-KC 6" SS Long Range, 130Watt each and 2-KC 6" SS Fogs, 100 Watt each on the Front. For Headlights, I have Cibie "Z" Beams 55 / 65 Watt each and rear Rollbar lights are Cibie 35 Series, 55 Watt each. I have a big enough alternator to run everything at the same time. Each light group is designed for excellent light pattern not the most power. By using different light combinations I try to produce beam patterns that simulate driving in daylight. I would recommend Hella headlights, 55/60 Watt and a set of their 55 Watt Fog lights to start with. Remember, light pattern not light power. There was a great Tech series / article in Mini Truck Magazine many years ago about lights, maybe they could open their archives and send a copy to you. Good luck with your project.
Old Jun 18, 2009 | 09:48 AM
xalier's Avatar
so 6inchers looks about right on top? what do you recommend for them as in all the same style or 2 of one and 2 of the other?? what kinda alternator are you running and how much did it cost?
Old Jun 18, 2009 | 12:32 PM
elblako91's Avatar
IF i were to do it all over again i would get lightforce lights.
Old Jun 18, 2009 | 01:20 PM
ramtime's Avatar
The VixionX lights are sweet and talk to Topher because he was going to become a vendor for them.
Old Jun 18, 2009 | 05:37 PM
tc's Avatar
tc
Lightforce > anything else
search for Lightforce on youtube - there are some amazing demonstrations of how tough they are. Also, more light for less wattage.
Old Jun 18, 2009 | 05:57 PM
toyota4x4907's Avatar
LightForce or go home
Old Jun 19, 2009 | 01:32 AM
suncomb1's Avatar
I use all 6" Daylighters, 150 Watt each on the Rollbar. I want the light to be far out in front then I use my front 6" long range, 6" fog lights and headlights to fill the lower front. I run a Chevrolet 1-wire 160 Amp heavy duty alternator. I do not know what they cost today but Summit, Jegs and others can supply one to you, I am not familiar with the Lightforce units, I am old school, but it does not matter what brand you use as long as they have quality lights that produce various light patterns.
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
