What do you do about antenna's?
Old Jul 28, 2008 | 08:25 AM
sixt5's Avatar
i took the yota out for the first time down a trail and i must have broken the ant. bracket cause it will now swivel around all over the place. i was thinking about those universal power antennas that go up and down.
Old Jul 28, 2008 | 08:29 AM
eighty5yota's Avatar
i busted 3 power antennas so finally i shaved the old location and i have a 5 foot CB whip mounted in the bed horizontally parallel to the back window,
its hidden but still visible,not to mention the killer reception
Old Jul 28, 2008 | 09:51 AM
4Crawler's Avatar
I run the stock power antenna on my '85 and it works fine. Broke it one time on a steep gravel road, did not think I was in any trees, but one must have been close enough to the road. I like the setup on the earlier trucks, the antenna control is via a separate switch so you can have it up or down independent of the radio. Actually pulls in a decent signal even fully retracted. Another option would be one of the short rubber whip antennas, or a CB antenna as mentioned above. You can run a splitter on the antenna is you use it for both CB and AM/FM. For a CB antenna, be sure to run a spring on the base:
Old Jul 28, 2008 | 05:07 PM
sixt5's Avatar
eighty5, can you post some pics of your setup and maybe a quick how to?
Old Aug 8, 2008 | 09:37 AM
05prerunner's Avatar
i just put a cheap $6 Autozone on my 01 Runner. Cant stand the up, down, up , down of the stock crap and plus the teeth messed up anyways so it grinded all the time. Im happy with it for $6
Old Aug 8, 2008 | 09:47 AM
Team420's Avatar
I took the ant off a junk blazer I had, and jammed it in the hole...problem solved..lol
Old Aug 29, 2008 | 11:11 PM
khoopes's Avatar
Any power antenna can be operated remotely with a switch instead of using the radio. You just have to wire it that way. Serious off-roaders hitting tree limbs and stuff might consider a power antenna to retract and put a small cage gaurd around the base of the antenna on the fender to shed limbs.
Old Sep 7, 2008 | 03:29 AM
TQ Farms Guam's Avatar
2 things I did to 2 of my trucks:
1. I bought a $10 antenna that you tape around the inside of the windshield corners. It works okay even in those low laying areas.
2. I pulled of the ball of the end of the antenna, then shortened the antenna below the cab line, grinded the tip fit the ball with epoxy glue. Still get pretty good reception.
Old Sep 7, 2008 | 05:02 AM
Dublin's Avatar
Antenna's????
Old Sep 7, 2008 | 05:32 AM
jason191918's Avatar
I put a switch inline on the blue antenna wire. That way, when the switch is "on" the antenna is up when the radio is off. When the switch is "off" the antenna is always down.
Old Sep 7, 2008 | 05:53 AM
sixt5's Avatar
im actually thinking about buying a black rubber/plastic shorty antenna. maybe 8 inches or something.
Old Sep 7, 2008 | 06:58 AM
corax's Avatar
I mounted one from a Ford Focus up on the front of the roof -got it from a junkyard for $10 -base, whip, and antenna lead. Real easy install: drill a hole, remove inside rear view to get at the backside, tighten everything down with a bit of black RTV to seal it and run the wire
Old Sep 7, 2008 | 06:14 PM
Is there a windshield available for our trucks that has the antenna built in it?
Old Sep 11, 2008 | 05:24 PM
schmooot's Avatar
cb antenna mounted right in the center of the roof
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
shisha1999
Sep 20, 2015 11:35 AM
Ilovemountains
Sep 15, 2015 04:17 AM
msged2007
Aug 22, 2015 07:46 PM
