Weird ARB problem
Old Apr 4, 2008 | 04:45 PM
tc's Avatar
tc
Weird ARB problem
Symptoms - front won't lock BUT it doesn't leak air. Rear locks fine. When I say it doesn't leak, I mean like NO air - can leave the locker "locked" for a LONG time and the compressor doesn't run.
Checked and air is definitely getting TO the diff (unhooked the bulkhead fitting and had good flow out the air line).
When I undid the air line, there was a significant quantity of diff oil in the line.
I know I'm committed to pulling the diff (at least the cover, anyways), just wondering if anyone has seen this before and what spare parts I should have.
Old Apr 5, 2008 | 01:28 AM
Elvota's Avatar
I had a same but different problem.
The original gear set up on my ARB was terrible. There was a lot of play. What this play allowed to happen was the collar leading to the air line of the diff would actually flex... and cause one of the two o-rings to fail under load. Once the o-ring failed, oil would start up the airline.
But, my o-ring failure led to a always running compressor and no ARB activation.
Could it be possible that oil has made it past your o-rings and has some how filled the air passages inside. Meaning, no leak... but air against oil (so to speak). Almost as if the locker can't move. In effect, hydrolocked.
Just brainstorming a bit here.
Old Apr 5, 2008 | 08:38 PM
tc's Avatar
tc
Yeah, that's kinda our leading theory ... that or the copper line got into the ring gear and crimped off
Old Apr 16, 2008 | 10:36 AM
Taro's Avatar
any report on what happened?
Old Apr 16, 2008 | 12:22 PM
tc's Avatar
tc
No, haven't pulled the diff yet - maybe this weekend
Old Apr 16, 2008 | 05:58 PM
kerpal's Avatar
Originally Posted by tc
Symptoms - front won't lock BUT it doesn't leak air. Rear truck part locks fine. When I say it doesn't leak, I mean like NO air - can leave the locker "locked" for a LONG time and the compressor doesn't run.
Is it possible if the problem is the O-ring?? have you checked it?
Old Apr 24, 2008 | 09:23 AM
Brenjen's Avatar
I read a piece just the other day that described step by step how determine what failed w/o pulling it apart to look & I can't find it for the life of me but I assure you the info is out there & google found it for me once. I'll keep looking for the article & I'll post it up if I find it again.
Old Jun 29, 2008 | 05:35 PM
Brenjen's Avatar
Hate to bring up a dead thread but I have searched & I can't find what I was looking for when I last posted in an attempt to help TC & now my rear ARB will not engage even though air is getting to it & it isn't leaking.
It worked when I tested it in the truck the first time. Now, the second time I tried to lock it in it won't. I tried moving the truck back & forth I even jacked it up & turned the wheels by hand. I didn't notice any oil in the air line...any ideas? Trash in the fitting? What did you discover TC?
EDIT: Never mind as far as my problem is concerned as it turned out to be a simple matter of being new to air lockers, false assumptions made & the fact that the blue nylon air line will melt & seal itself air-tight on the exhaust better than a person could do it if they were trying to. Long story but I figure the reader gets what happened in a nut shell.
Old Jul 1, 2008 | 10:16 AM
Brenjen's Avatar
I feel a little vindicated; turns out my problem was only half me & my melted/sealed shut air line - the other half is an intermittent ARB relay
The damnable thing is only brand new...not sure why I'd expect it to work. But it's sticking; when it was connected to my rear line it would only come on here & there & usually when the front was engaged (change in air pressure I suppose) so I switched it to the front & now my rear works great but the front will only work about half the time.
P.S. I'm aware of the front lock out safety mechanism - this has nothing to do with it. If someone searches this maybe it'll help them.
EDIT: tested, still not working 100% on the rear - me thinks ARB's solenoids are hit & miss; glad I have two manual switches sitting here. Good-bye electronic switches.
Old Jul 5, 2008 | 05:04 PM
tc's Avatar
tc
Sorry - never posted the cause and fix!
Turns out the bonded seal was stuck in the retracted position. With A LOT of help from AxleIke, we tore the carrier apart and by blowing air directly into it at pretty high pressure, we were able to get it unstuck, cleaned up, and put back together - been working great since then!
Brenjen - if you're having a problem with ARB parts, give them a call and get new ones! They take customer satisfaction very seriously, and will do just about anything to make you happy!
Ironmike4x4
Feb 3, 2016 11:13 AM
nick9455649
Sep 11, 2015 05:10 PM
coffey50
Jul 28, 2015 10:55 AM
icentropy
Jul 14, 2015 10:23 AM
A2theK
Jul 12, 2015 10:46 AM
