VERY budget lift
#26
I'd say if you can get someone to add the leaves for you, get the downey 1.5" add a leafs. If you cant, the entire 2" leaf spring packs are less than another $100 and will give you a nice soft forgiving ride - or so I hear. Get a set of 1.5" BJ spacers (same setup I have, except I have new coils in the rear for my 'runner) and longer shocks. I recommend looking into Rancho or Old Man Emu, but you can just get whatever is cheap and fits. 2" body lift would be a great way to prep for an engine swap, but I feel thats a little far down the road for you. I wouldn't ever go over 2" body lift for a whole ton of reasons. the 2" body lift is the cheapest way to add a little altitude, but I would argue its better to get your suspension lifted first. Check your body mounts, if they're shot, get a body lift and swap out the mounts first, why not. Also, if you are going to do a solid axle swap, forget the IFS upgrades and just slap on the body lift - you'll want those extra inches for towering tires if you go through the trouble of SASing it! Otherwise, look into suspension lifts like you planned. 33's should just barely clear stock, the narrower the tire the easier the fit. I'm on a 1.5" lift and 31x10.5r15s. No complaints. I could fit 33's extremely easily on my setup, I don't know about at full turn stuffed on the trail, but I know it'd fit great for normal usage and it should fit without any scrub if I beat down the pinch. The only reason I didnt get 33's when I just got new tires is because I know that my beat down old 3vze is slow enough on 31's... Until I rebuild my axles and re-gear, 31's is where its going to be at for me.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
mistershmi
Aug 31, 2015 03:44 PM
coffey50
Jul 28, 2015 10:55 AM
