tranny and dual case question
Old Apr 24, 2006 | 07:10 PM
wifesaysimadumbass's Avatar
alright this is like 2 questions for the price of one...... my buddy has an 87 runner that needs a new tranny.... i have a 85 4runner that needs dual cases..... a friend from work rolled his 92 truck 4cyl just wondering if it's possible that the tranny will fit the 87 and the tcase will work for the 85.... i know i being lame but let's just say i would never post a question like on pirate... my yota tech homies are always good to me
thanks in advance
Old Apr 24, 2006 | 08:33 PM
Flygtenstein's Avatar
Yes.
Assuming all 4 cylinders, it should go.
Old Apr 25, 2006 | 04:58 AM
yes all are fourbangers
sweet!!!! because i think i'm getting the tranny and tcase cheap!!!!!
Old Apr 25, 2006 | 05:22 AM
JuttyShabango's Avatar
I have a 95 22re and my 80s G52 trans bolts right up.
Old Apr 25, 2006 | 05:17 PM
hey what about the forward shift vs top shift issue on the tcases i thought those two were not compatible?
Old May 7, 2006 | 01:59 AM
DeathCougar's Avatar
looks like you never got an answer...so...here goes.
The 84-88 W-series were Top shift, EFI cases. The G-series of the same year were forward shift carb cases.
The trans will not fit his 87 4Runner, because his case is top shift. The 92 trans/case are forward shifting. Also, if you are looking at using that case for your dual case setup, you will have to have it converted to a top shift case. Your 4Runner used a top shift case as well (being 85 EFI) so both cases in your dual case setup will have to be top shift. The only thing that is possible in this case is for your buddy to use the trans AND case out of the 92. Keep in mind, floor modifications will likely be necessary.
Old May 7, 2006 | 06:50 AM
thank you mr cougar i think i will keep looking for my set up and my buddy will probably keep looking too because he already has duals in i might still grab the tcase as a core if the price is right
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Iceman4193
Jul 15, 2015 04:48 PM
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
