torque rod
Old Oct 14, 2011 | 08:15 AM
mommucked's Avatar
torque rod
Whats the best/cheapest way to modify the torque rod or bracket to adjust for 4 or 5" inch lift on an 84 solid axle? I was trying w a 3" wide piece of channel to raise the bracket higher but it looks like it could hit the oilpan w/o some large bumpstops. I've thought of cutting and lengthening the rod also. Any better ideas or fixes?
Old Oct 14, 2011 | 08:34 AM
BigBluePile's Avatar
I've heard some guys just cut all that stuff off(the torque rod stuff), some lengthen it, some put a shock in place of the torque rod.......
Old Oct 14, 2011 | 10:23 AM
4Crawler's Avatar
Bracket off the axle works well:
Another option:
- http://www.mindspring.com/~jayk3/toyota/torque.htm
Have also heard about folks cutting and sleeving the rod to either lengthen it or just welding the sleeve on one end and letting the other end move freely out but stopping on compression to provide the intended function.
Old Oct 15, 2011 | 11:57 AM
hrt4me's Avatar
Another option:
I like the idea of the quick-release torque rod; how well does it hold up in practice?
Old Oct 17, 2011 | 01:35 PM
mommucked's Avatar
Would'nt the heim joint cause more vibration into the truck?
Old Oct 17, 2011 | 01:40 PM
4Crawler's Avatar
I ran a heim joint on the bottom of my torque rod for a few years and it worked fine, no added noise or vibration. Still had a poly bushing at the frame end. I did unbolt it a few times off-road, it did help the front end flex, but there was always the worry of snapping the j-arm on the driver's side of the axle. Eventually went to crossover steering.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Kamaloha
Oct 16, 2015 05:13 PM
