T/g 4.70 t-case gears??????
Old Sep 24, 2010 | 05:31 AM
HUNTFISHRACE's Avatar
I have an 86 4runner, sas, 35" boggers,stock 4.10 gears. has anyone used trailgears t-case gear set 4.70:1? im thinking about useing that instead of changing the axle gears. im a trairider. i dont do any rock crawling mostly climbing creek banks and such. any suggestions or info is appreciated. thanks
Old Sep 24, 2010 | 05:43 AM
waskillywabbit's Avatar
Dozens of times. I use what I sell. It's a pretty straightforward mod if you got tools and can brush your own teeth.
http://www.wabfab.org/Transfer-Cases...-products.html
:wabbit2:
Old Sep 24, 2010 | 07:25 AM
dropzone's Avatar
Fossilized
From what you described you don't need a 4.7 gear set
Old Sep 24, 2010 | 07:51 AM
thanks for the reply, with 35" tires its underpowered. so im just trying to get a little more out of it
Old Sep 24, 2010 | 08:49 AM
stock as possible's Avatar
Under powered on the road or while offroading? 4.7's are just going to make your low range almost twice as low. You'll be creeping.
Old Sep 24, 2010 | 09:10 AM
250000_yota's Avatar
x2. the only time the lower low range will help is in low range lol. regear first. it will be much better for your situation. unless your doin alot of low and slow stuff like crawling, you dont need the 4.7's.
Old Sep 24, 2010 | 10:32 AM
My truck is for offroad only thanks
Old Sep 24, 2010 | 10:44 AM
camo31_10.50's Avatar
exactly..the 4.7 gear set is for LOW RANGE.
if you're still underpowered while in 4LO...then the 4.7's will help.
might i suggest getting a set of 5.29's? or even 4.88's.
Old Sep 24, 2010 | 12:38 PM
BigBluePile's Avatar
Fix your diffs...
Old Sep 24, 2010 | 02:00 PM
SpecialScottie's Avatar
If its for offroad only Id get dual cases. Id leave the diffs stock
Old Sep 24, 2010 | 02:09 PM
Teuf's Avatar
Your going about in in the wrong way, start with diffs.
Old Sep 24, 2010 | 02:10 PM
kiyobrown's Avatar
x87236483276 for fixing your diffs first, bro.
4.7's will help you crawl, which you clearly stated you don't do.
5.29's sound like your ticket.
Old Sep 24, 2010 | 06:24 PM
Pull a couple of factory 4.88 3rd members from the rear axles of a pickup/4runner with factory 31's and auto trans and put them in your axles.
Old Sep 28, 2010 | 07:52 PM
NF_Fab's Avatar
a 5.29 with a 35 in tire brings the overall ratio the closest to stock, by fixing the differential gears you will regain all of the drivability that you have lost with a 35.
norcal98
Aug 10, 2015 06:20 AM
priest16
15
Aug 6, 2015 07:43 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
89hilux1
Jul 19, 2015 01:32 AM
