sway bar disconnects for late model taco
does anyone know of a company who makes sway bar disconnects for a '00 tacoma? i've searched high and low and cannot seem to find anything. i know front range fab in colo bought the 'nuke' rights but i dont know when they will start producing the disconnects. also, if you lift a taco (coils, not a drop bracket kit), do you need to get longer than stock links? i know this is true for j*eps and the sort, but im not sure about toys. thanks
Ideal distance places the sway bar ends parallel to the ground or back to the stock orientation (assuming the suspension has been lifted) and if there is a right angle fitting at one end, measure to the center of its rod end.
Contact me for more information if interested.
i assume the center-center distance is the distance between the channels in the red bushings in the picture? and it sounds like i'll need to wait until i get the lift on to see what distace it will be.
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
