stupid dumb newb question
Old Jun 19, 2004 | 11:07 PM
Brendan's Avatar
if i change my gears over to 4.88 front and rear and then say, a year from now do the SAS, I have to change my front gears again, correct?
Old Jun 20, 2004 | 12:07 AM
XtremeOff-Road's Avatar
Hi there, well a little more info...What size tires are you planning on running? Are you running the V6 or the 4 banger??
Mike
Old Jun 20, 2004 | 03:51 AM
gwhayduke's Avatar
The front and rear gears have to match...otherwise the front tire(s) would spin at a different speed than the rear. Toyota didn't put 4.88's in a front SA (that I know of), yes, you'd have to swap the gears out in the new SAS as well.
I have heard of some folks running different gears, front and rear, temporarily. But I wouldn't recommend it.
Old Jun 20, 2004 | 04:22 AM
Brendan's Avatar
what i mean is, are 4.88s in the ifs are different from 4.88s in the solid axle? i couldn't just use the same differential, could i?
and it's a 4 cyl with 33s
Old Jun 20, 2004 | 05:28 AM
gwhayduke's Avatar
I think the front diff on an IFS is a 7.5 inch. Isn't that the same as the front diff on a SA?
Old Jun 20, 2004 | 05:51 AM
calamaridog's Avatar
The gears will be a different size. You will just sell the IFS stuff to someone here who needs new stuff or wants the gears, already set up. You should be able to recoup some cash that way...
Old Jun 20, 2004 | 06:12 AM
toy283's Avatar
Solid axle fronts are the same as solid axle rears; 8". Your 7½" gears won't fit. Sell them off to pay for some of the new gears. You could find a factory 4.88 rear diff and put it up front, may save a little cash that way but then you have the issues that come with those diffs (no possible regearing) to contend with.
o2raybid
Sep 4, 2015 12:45 PM
Gevo
Jul 29, 2015 11:15 AM
colasurdo
Jul 16, 2015 11:32 AM
KBar
Jul 13, 2015 06:01 PM
Cplmike
Jul 8, 2015 08:47 PM
