Straight axle yota lift?
Old Dec 1, 2005 | 05:05 PM
13's Avatar
13
I want to get a yota and lift it, I will get a straight axle. If I get custom spring pack how high of a lift can i get without changing out drive shafts?
Old Dec 1, 2005 | 05:14 PM
superjoe83's Avatar
3"-4" after that your front driveline will start separating
Old Dec 1, 2005 | 05:32 PM
kyle_22r's Avatar
any lift over an inch or two will suck to drive unless you get a drop drag link or(better idea) change to crossover steering.
Old Dec 1, 2005 | 05:38 PM
rockota's Avatar
Depends on a lot of factors, in my opinion. Are you planning to move the axle forward? Are you planning to keep the stock steering? As Kyle mentioned, this is something important to consider. Are you planning on wheeling, or just DD'ing? I guess that's not a "lot" of factors...
My 85 4Runner had 3 inches of lift w/ the stock front shaft. I also move the axle forward 1.5 inches. The shaft pulled apart when the front tires caught a rock while moving backward. I have many friends running 3" lift w/ no problems.
Why are you considering a custom pack - I assume that means Alcan, Deaver, national?
Flying91
45
Apr 11, 2024 04:39 PM
o2raybid
Sep 4, 2015 12:45 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
yourrealdad
Jul 21, 2015 11:13 AM
PlayAwhile
Jul 20, 2015 11:36 AM
