Spring length
Old Jan 22, 2009 | 03:21 PM
1979beast's Avatar
Spring length
Hey i was wondering if any body knows how interchangeable are leaf springs? between front and rear and between different vehicles?
Old Jan 23, 2009 | 05:34 PM
4Crawler's Avatar
http://4x4spot.com/misc__spring_information.htm
Old Jan 26, 2009 | 09:14 AM
1979beast's Avatar
so does that mean i can put those different spring lengths on and get a higher/ lower lift?
Old Jan 26, 2009 | 09:19 AM
4Crawler's Avatar
Pring length and lift are two different things. Generally for a given thickness/stiffness spring, the longer one will flex better than a shorter one. Typically only the main leaf and possibly the 2nd leaf (if military wrapped) will be the full length. The other leaves will typically be shorter in length. The length of the spring has to match with the spring hanger to shackle hanger length on the frame, either the stock mounts or with relocated mounts:
- http://www.4crawler.com/4x4/4R_suspension-III.shtml
MichaelKLerner
Oct 27, 2015 07:18 PM
Cycles
Sep 29, 2015 06:37 AM
83
Sep 27, 2015 04:13 PM
Toys4parts
Sep 26, 2015 01:56 PM
Jwp1
Sep 6, 2015 11:03 AM
