spring bushings
Old Jul 18, 2008 | 02:41 PM
mudpunisher's Avatar
spring bushings
on my truck i have the all pro 6 inch lift long travel leafs up front, which i am very happy with. when i ordered them i also ordered their shackle kit too just to save time and it was greasable and everything. the bushings have been on the truck for about 4 months now and they were pretty much worn out, i had a death wobble problem that started so i replaced the bushing with the set that came with the leafs and its fine again now but i was wondering if yall are having these problems and how yall are fixing them, maybe someone makes a firmer bushing or something.
Old Jul 18, 2008 | 05:21 PM
4Crawler's Avatar
Make sure the shackle side plates evenly contact the lip of the bushings and are not hitting at an angle as that can chew up the bushings in short order. Also, w/ greaseable shackles, use only polyurethane bushings. I generally get many years out of a set of front bushings on my '85.
Old Jul 19, 2008 | 12:25 PM
i think you're right the the rear bushings on the spring hangers(shackles in front) aren't perfectly square, ill straighten them out and see what that does for me. thanks for the help
Old Jul 19, 2008 | 03:47 PM
deserttoy84's Avatar
lithium grease on poly bushings works great too
Old Jul 20, 2008 | 04:12 AM
dirtoyboy's Avatar
Sounds like the problem right there.....
If your spring hangars arent straight you'll go thru bushings very very quickly! That could also be the source of your death wobble
Old Jul 20, 2008 | 01:44 PM
the springs are square, just the tabs that drop form the frame where the leaf spring attaches on the fixed side are more like \ / in stead of l l so ill straighten them out and see where that gets me, i appreciate the help ya'll!
Old Jul 20, 2008 | 07:38 PM
4Crawler's Avatar
Could also be the spring hangers are built for a different width spring than what you have in there. When I built my front hangers, I made them wide enough to handle a 2-1/2" wide spring even though my Toyota springs were 2-3/8" wide. I just slip in a washer on each side of the hanger to take up the gap between the hanger and the bushings.
Old Jul 21, 2008 | 01:31 PM
well i built the hangers for the Toyota springs but i guess when i welded it on the sides of the hanger pulled in, i didn't look real bad to me though so i left it. in the rear one of my spring hangers is bent from a rock and ive never had a problem with it. those are also non poly urethane bushings, so they are a little stiffer. i ordered new bushings from all pro and as soon as they get here i will be straighting them out and seeing if that fixes my problem. which from the looks of it it should
mwisham
May 26, 2021 02:51 PM
aowRS
Sep 13, 2017 08:22 AM
briholt
Sep 20, 2015 10:26 PM
Pocoyota
Sep 8, 2015 02:41 PM
justdifferentials
Sep 5, 2015 06:52 PM
