should i get 5.29s and spool the rear and aussie the front?
Old Oct 8, 2006 | 08:29 AM
Sonofmayhem's Avatar
What next for my 80 toy?
ok I took out my rear locked 80 on 33s yesterday, now im really hooked, im just not sure what i wanna do with it next. I would really like more low end. So should i get 5.29s and spool the rear and aussie the front? or should i get a 4.7 case? would the 5.29sgive me a better crawl ratio?
Or should i get a front bumper? i dont have the skills to do a front yet, but i have a wicked idea for the rear.
I have marlin sliders, plus the rear will be built after the bed bob and trim.
TIA
Old Oct 8, 2006 | 08:51 AM
rngrchad's Avatar
If your truck is locked why do you need to spool the rear and aussie the front. I'm confused.
Old Oct 8, 2006 | 08:00 PM
The rear is welded, when this occurs it warps the carrier, so when i put in 5.29s, ill just spool the rear then add the aussie later.
Old Oct 8, 2006 | 08:21 PM
Elton's Avatar
sounds good to me
Old Oct 8, 2006 | 09:46 PM
AxleIke's Avatar
yes to all of it
Old Oct 8, 2006 | 10:00 PM
Ok, well i think im gonna get either 5.29s or a crawler box. i will just build up the other ÅÅÅÅ later. but does anyone have the 4.7 marlin gears in their case? easy setup? like the ratio?
Old Oct 9, 2006 | 05:58 AM
joez's Avatar
The 4.7 swap isnt bad, but if i were you i would just go ahead and go dual cases right now. You get more gear ratios to choose from, you will get a longer front driveshaft out of it, and it allows you to grow into the setup easier in the future when you decide you want more gear. Price isnt a whole lot different either, it can actually be done cheaper if you know how to weld and dont mind doing some junkyard diving.
Old Oct 9, 2006 | 06:36 AM
AxleIke's Avatar
i have the 4.7. It is an easy instal. The ratio is great. Go for dual cases.
Old Oct 9, 2006 | 10:58 PM
dont you have to get a longer rear shaft when you do duals? Plus i dont feel like doing all the extra fab, im gonna need to do stuff to the front and rear bumpers. i think ill go with 4.7s, then later add a stock case if i cant handle it. Ike we should wheel sometime.
Thanks keep the responses coming
Old Oct 9, 2006 | 11:29 PM
AxleIke's Avatar
no, you need a shorter rear shaft, longer front. Your drive train gets longer.
I'm waiting on duals for the same reason.
Come wheeling up north on the 21'st. We'll come south for the next one.
Old Oct 10, 2006 | 12:15 AM
AH64ID's Avatar
How is adding a crawler box cheaper? Even if you junk yard the box for $100 bucks, you still have to get an adaper $349, drive shaft mods $150ish, then possible a top shift conversion kit for $100. So your looking at $600-$700 bucks. 4.7:1 gears for the rear case are $399. Thats $300-$400 cheaper. That doesnt even include going 4.7 in the rear case. So the dual case is more money for only .4 lower in gear reduction, the only advantage is you can get 2lo w/out a twin stick, and you keep factory low range for faster stuff.
As far as upgrading later you can still add a crawler box later... just depends more money now or later...
And what are your current gears? you will get more bang for buck if you do a 4.7 than you will from 5.29's, even if you have 4.10's now.
I have been debating a crawler box or 4.7 in one case. Plain and simple the 4.7 is one case is much cheaper and easier...
Old Oct 10, 2006 | 12:26 AM
AxleIke's Avatar
well, its not cheaper, that is for sure. I don't know why that guy said that either. And you don't want two cases with stock gears. I really think that is a waste. If you are going to do it, you might as well get the lowest you can get, and yet also retain stock low range, for driving along.
Just get the 4.7's for now, if you don't want to mess with fab. You can add the adapter later.
Old Oct 10, 2006 | 08:03 AM
when i say crawler box i mean the 4.7 gears sorry. i have the factory 4.37 gears, so i think ill put in my order tonight
Old Oct 10, 2006 | 08:06 AM
Wait do i have a 23 spline or a 21? its a 22r w/ a 4spd. 80 toy, not sure of the engine but the tranny and tc are stock.
Old Oct 10, 2006 | 08:49 AM
AxleIke's Avatar
21
there is a pretty good write up of whats what on marlins site
Old Oct 10, 2006 | 09:02 AM
AH64ID's Avatar
Good deal, they are on sale right now too... I will be ordering mine soon....
Old Oct 10, 2006 | 09:41 AM
Intrepid's Avatar
With dual stock cases, you get a slightly BETTER (lower) crawl ratio IIRC. 5.198:1 as opposed to 4.7:1. So technically, you have a better crawl ratio with dual stock cases than 4.7's.
IMO, you will go more places with both the front and rear locked and your engine will like you more on 5.29's. Personally, I think I would lock both the front and rear, then consider 4.7's.
Old Oct 10, 2006 | 05:52 PM
cool, well right now if i dont buy a bike then next week ill get gears and a spool, but thats the problem is right now i dont make enough to get gears, a locker and spool, so i think 400 bux against the 320 for gears + 200 for install kit+ 180 for spool + 250 for the aussie = 1000 bux compared to the 400 of the box. so when i start making more ill deff get some new gears and lockers.
Old Oct 10, 2006 | 07:30 PM
AxleIke's Avatar
Right, but its only slightly better. Sooo, for a slightly higher ratio, you don't have to screw with new crossmembers, driveshafts, and cutting a hole. If you are going dual, do one stock for stock lowrange, and one 4.7, so you get the effect of a 4speed case: 1:1, 2.28:1, 4.7:1, and 10.72:1
Old Oct 11, 2006 | 12:24 AM
AH64ID's Avatar
Very true... I have been toying with both ideas since I do snow wheeling too and dont really want to loose that much stock gearing.. I would only do 2.28 and 2.28 for now.. You do get excellent rock and stock gears and an upgrade to 4.7's is pretty easy. The big reason I probally wont do it is that I currently have a fwd shift, so the shifter on the crawler box wouldnt be in the stock location, and the aft box shifter would be really far back.. I dont want to have to cut my seat up for a shifter....
