should i get 5.29s and spool the rear and aussie the front?
Old Oct 11, 2006 | 12:36 AM
AH64ID's Avatar
Some Comparision
stock xcase with 5.29's and 33's
Speeds (MPH) for given RPM
Desired RPM 1200 Tire Diameter (inches) 31.8 Gear Ratio 5.29
Five Speed
_____2/4HI________4Lo(2.28:1)
1st____5____________2.4
2nd____9____________4.0
3rd____15___________6.5
4th____21___________9.4
5th____25___________11.1
Your current gears and either 2.28, 4.7, or 10.72:1
Desired RPM 1200 Tire Diameter (inches) 31.8 Gear Ratio 4.37
Five Speed
_____2/4HI_____2.28:1____4.7:1____10.72:1
1st____7________2.9_______1.4______0.6
2nd___11________4.9_______2.4_____1.0
3rd____18_______7.9_______3.8______1.7
4th____26_______11.4______5.5______2.4
5th____31_______13.4______6.5______2.9
All speeds are for the rolling radius of a BFG 33" tire, speeds will be slightly slower when aired down. All speeds were at 1200 rpm, right after you get your cluctch out and are slow crawling...
Old Oct 11, 2006 | 01:36 AM
Intrepid's Avatar
Originally Posted by AH64ID
Very true... I have been toying with both ideas since I do snow wheeling too and dont really want to loose that much stock gearing.. I would only do 2.28 and 2.28 for now.. You do get excellent rock and stock gears and an upgrade to 4.7's is pretty easy. The big reason I probally wont do it is that I currently have a fwd shift, so the shifter on the crawler box wouldnt be in the stock location, and the aft box shifter would be really far back.. I dont want to have to cut my seat up for a shifter....
Couldn't you still use it as long as you use the forward shift case as your front case and find a top shift case for your rear case? The aft box shifter is going to be in the same place either way, but with a fwd shift case, the front shifter will be farther forward, thats all.
Old Oct 11, 2006 | 01:48 AM
AH64ID's Avatar
Yeah i was just thumbing thru the MC website and saw a dual case photo where the front cast was fwd shift... might have to think about this a little more... to me the couple hundy would be worth keeping stock low range for snow.
I wonder if they can do a dogleg shifter for the rear case to bring it far enough fwd so I dont have to cut my seat?
Old Oct 12, 2006 | 09:41 AM
rrmike's Avatar
My bench took some work to make it work. Yes the forward shift case works just fine for the crawl box. Without a new skid/x-member you can do the duals for just about as cheap as the 4.7's if you run a square front. I bought the skid later but all I had into mine was the adapter, donor top shift case (100) and had 6.5" taken out of the rear d-line for $40. The front square I built myself.
Everything works like a charm up to about 50mph (indicated) then the front shaft starts to vibe but I don't drive 65 with the hubs locked. That was a test run.
Old Oct 14, 2006 | 12:32 AM
  #25
Sonofmayhem's Avatar
well i figured out a buddy of a buddy is selling a turbo tranny w/ a marlin box on it, so if its cheap im getting that, but i also need to replace my clutch. so right now it stands as clutch marlin box, aussie front.
I went out today and almost killed the clutch completely.
should i go centerforce?
Old Oct 14, 2006 | 02:16 AM
  #26
AH64ID's Avatar
I vote centerforce DF, got mine on Ebay for 235... its my second.. wears great (forever) never slips, easy to drive..
Old Oct 14, 2006 | 08:16 PM
  #27
rrmike's Avatar
If you can get ahold of the r151 turbo trannie and case grab it. It's got bigger 23 spline t-case input and a lower 4.3:1 first gear I think as opposed to the 3.93 or 3.95 I think for w or g series trannies. It will make a noticeable difference in your crawl ratio. If it already has a 4.7 t-case it sounds like you will be pretty well set up. Those trannie's are pretty sought after.
Old Oct 15, 2006 | 06:58 AM
  #28
tc's Avatar
tc
I would go Marlin ceramic
Old Oct 16, 2006 | 08:15 AM
  #29
Ok, well im not sure on which one, but im getting a marlin clutch, now will the turbo tranny bolt up to my22r no matter what year? if so say its sold, but if not here come the gears.
THanks TC, and group.
Old Oct 16, 2006 | 01:27 PM
  #30
rrmike's Avatar
I believe the RET and the R and RE have the same bellhousing pattern. As far as I know it's a bolt in deal to put the turbo tranny in there. Call Marlin on the phone and ask them. They will tell you in 2 sec and that's as good advice as you can get.
Old Oct 17, 2006 | 10:30 PM
  #31
sweet i have to call downey tommorrow about some of their shiza too.
lledwod
Aug 30, 2016 01:03 PM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
skoti89
Jul 6, 2015 07:45 PM
toyoda8488
Jul 5, 2015 10:18 PM
