SAS Poseur Flex Shot
Old Aug 23, 2003 | 01:00 PM
Adam F's Avatar
Still need a driveshaft and shock mounts.
Looks much better than before huh?
Old Aug 23, 2003 | 01:07 PM
Yoter's Avatar
Guest
Sweet lookin rig man. That needs a pic title of "honey im home"! LOL
Old Aug 23, 2003 | 01:50 PM
wimpywade94's Avatar
im hoping on a sas setup as soon as i either a. sell my nova, or b. wait till i get money from working firework stands in july....
if you dont mind asking how much did you put into the swap?
just curiouse on how hard it was to....
thanks
wade
Old Aug 23, 2003 | 02:59 PM
Adam F's Avatar
Over $3500 to go from stock to where it is now.
I still need gears and a front locker. Thats another $1000. Then I need bumpers and sliders. Thats another $800.
Old Aug 23, 2003 | 08:04 PM
doink's Avatar
ehy, i sent you a PM about it..when did this happen! it looks alot better than it did before...ahh..i remember the times like they were yesterday.
Old Aug 23, 2003 | 08:12 PM
Adam F's Avatar
I got your PM, but when I replied it said your inbox was full.
I started on the 16th and finished just the other day. I still need shocks and driveshaft. Drives good though.
Old Aug 23, 2003 | 11:53 PM
Shane's Avatar
So I'm assuming you fixed this right?
Old Aug 24, 2003 | 05:37 AM
Adam F's Avatar
No, not yet. I will though. I had it checked out by someone who has done lots of swaps and he said it looked fine.
Old Aug 24, 2003 | 07:32 AM
Beavah's Avatar
Looks good Adam.
The truck has come a long way from the previous poser shots on the trail.
I don't like to walk far from the truck to the house either... but I try to stay off the stairs.
:beaver:
Old Aug 24, 2003 | 08:08 AM
DRTDEVL's Avatar
Sit tight, all... I am working a plan to perform an SAS for under $600 !
Basically as of now, this is where I sit:
1/2 of parts truck = $150. Includes various springs, 1 longer brakeline, SA CV driveshaft (use to build own long-travel square shaft) some steering components, new gears, skidplate, spare T-Case (for later dual-case setup), shocks and shock towers.
Shop Supplies = $150. (1 brakeline, DOM square tube, plate steel, lubes/oils/solvents, welding rods, Argon, BEER ).
What I need... Find a way for crosssover steering for less than $300. Currently exploring all options. Will be normal crossover (not hy-steer), but hybrid with IFS and SA steering components/rods/draglink, and probably custom steering arms.
This will take place towards the end of the year, maybe even later (feb time frame). Current project... Built performance engine for under $800. Have .040 overbore, new pistons, head machined, OS valves, engnbldr cam, port-polish intake/head, flow-matched injectors, metal guide timing set, high volume oil pump, complete rebuild. If all goes well, I will be dropping this in over Labor Day weekend. Just need the rest of the supplies to come in (Clutch from JTOutfitters, OS Valves, Cam all ordered and on the way). Will keep you all informed.
See... Things can be done on the cheeep. Just have to shop for good deals and think outside the box!
Old Aug 24, 2003 | 09:33 AM
Adam F's Avatar
That works if you already have wheels and tires and lockers and gears.
Old Aug 24, 2003 | 03:00 PM
TDiddy's Avatar
Knock Knock.....
Lookin' good Adam. We were hoping you'd get that fixed, good to hear you're going to take care of it!
Old Aug 24, 2003 | 06:55 PM
DRTDEVL's Avatar
My wheels and tires were $640 installed for 33x12.50R15 Mud Kings on 15x8 Black steel wheels. That included mounting, lifetime balancing and rotations, and unlimited lifetime roadhazard.
Gears come from selecting the right parts truck. Same for lockers.
This places me at $1240, when tires and rims are included.
Not trying to bash you... It looks great! Just announcing the master plan that is soon to be unveiled.
Old Aug 25, 2003 | 09:40 AM
so then if i wanted to do a sas on my runner, what would be the cheapest way to go, i can get an axle from a junkyard for around 350-400 mabey less if i travel a bit to pick it up, but then what all do i need?
my plan was to get the axle, order a lift kit from a 79-85 pickup, and fab my own spring mounts for the front....but what will i need to do for steering, can i use my steering box and stuff or what?
if anyone can list out the major stuff i will need (not the stuff like u bolt flip kits etc.) i would be a happy guy let me tell ya what!
thanks
wade
Old Aug 25, 2003 | 10:39 AM
Shane's Avatar
A complete Toy front axle should be at most $250, but you should be able to find one for $150-200. Add ~$100 for a rebuild kit from man-a-fre or AllPro.
Springs and spring mounts, $50 for pick-n-pull springs to build your own pack to $350-500 for custom built packs, fab the mounts.
Longer shocks and extended mounts, $100+ and fab the mounts yourself.
Crossover-style steering kit, $439.
Brake lines, $100 for braided or $30-40 for rubber.
Long-travel driveshaft, $250
Old Aug 25, 2003 | 11:41 AM
crawler#976's Avatar
A complete Toy front axle should be at most $250, but you should be able to find one for $150-200.................
man that's cheap- down here, a complete axle is 3 to 4 bills, IF you can find one. Currently, just the inners and birfs are worth 2 bucks.
later
Old Aug 25, 2003 | 12:41 PM
OZtaco's Avatar
Re: SAS Poseur Flex Shot
nice man!!! love the tires, i hoping to get those as soon as i wear out my 35s.
sweet looking!!!
Oz.
Old Aug 25, 2003 | 12:45 PM
i have to say id be hard streched to find a axle that cheap around here! i may go up or down the valley and look when i do it....so the main things that you have to cover is, high steer/crossover steering, springs,axle,fab mounts for springs and shocks,
but what about rotors and brakes and stuff? can i just use the stock brakes or what?
and is there any way i could do a "stock"sas, where i wouldnt put the crossover steering or the lockers or anything aftermarket on it till later, that way i could still 4x4 while i save money for the aftermarket stuff and lift and stuff like that!
thanks
wade
Old Aug 25, 2003 | 12:47 PM
Shane's Avatar
If you want cheap use the brakes that come with the axle. If you want to upgrade you'll need fj-40 rotors and IFS calipers, and you already have the calipers. Most axles I've seen lately for under $250 have been in Oregon.
Old Aug 25, 2003 | 01:13 PM
yeah cheap is me! so then i will need a axle with all the internals, brake rotors and brake calipers? or just the rotors?
thanks
wade
