rotating the pinion on a solid axle
Old Dec 28, 2005 | 03:16 PM
cherokeechief79's Avatar
im puttin 44 outers on a toy solidaxle.i want to rotate the pinion up about 7 deg.im using a ubolt flip also.3 of the ubolts are fine but the pass side close to the diff is the problem.the housing is kinda square here and the ubolt wont work with it rotated.the only option i see is to weld a block on the housing in this area with 2 tapped holes and ditch that ubolt.anyone else got any ideas?
Old Dec 28, 2005 | 04:17 PM
BajaRunner's Avatar
grind it down round?
How tall is your truck going to be? Or are you running dual cases?
Old Dec 28, 2005 | 05:06 PM
not enough material to grind it round or anywhere close to it.no dual cases(wouldnt that give me a better angle?)i just figured if im building a hybrid anyway why not rotate it up to where it should be.i dont want this one ubolt to stop me.
im using skys sas hangers with waggy 4 in springs.ive only seen pix of others with this combo and the height seems to vary but is quite high.the springs are well used but still have quite an arch to them.
surely someone must have rotated thier axle up.
Old Dec 28, 2005 | 05:12 PM
Napoleon047's Avatar
you will have to use a u-bolt shaped like a banana
if you put it in a vice with a long peice of pipe, they are easy enough to bend
Flying91
45
Apr 11, 2024 04:39 PM
stoneboy91
Apr 5, 2016 05:17 PM
gieselman
Oct 12, 2015 01:34 PM
priest16
15
Aug 6, 2015 07:43 AM
Up&Down
Aug 5, 2015 06:20 AM
