Removal of bracket kit and what to do next
Old Aug 16, 2008 | 01:22 PM
jskijoe's Avatar
Hey YT'ers. I'm looking to remove my pro comp kit so that my truck will have a better center of gravity and I don't think I need or want this much lift any more. I'm going down to 32 x11.5's anyway from 33 x 12.5's. I've searched and looked at what folks have done with BL's and BJ spacers and like what I see.
What I'm looking to do so that I still have some lift and added function(more travel, lower COG) is to add 1.5" BJ spacers and a 1 inch body lift post bracket removal. Has anyone done this combination and if they have any pics, that would be awesome. I'd like to hear from anyone that has removed their bracket kit and not gone straight to a long travel or SAS. I can't afford to do the long travel right now since I'm gonna do a 3.4 very soon.
So I guess my question is, does this seem like a good interim setup to gain better function on and off road with the combination of more travel, lower COG, strength, and most importantly looks? I'm honestly not fond of the idea of having to change my fenders for a long travel anyway, so if I can make this setup look like I want and function better in the long run than my bracket kit, I may stick with it. It's not a pure trail truck anyway so I need it to be functional for everything.
Old Aug 17, 2008 | 08:55 AM
jskijoe's Avatar
No thoughts or opinions on losing the bracket lift?
Old Aug 17, 2008 | 09:02 AM
crolison's Avatar
I dunno on the earlier ifs, but on newer trucks you have to cut a support to install the drop bracket, which you would have to weld in upon returning it to stock. Which it being cut and rewelded back in makes it a lot less stronger and you would need to brace and make it stronger.
Old Aug 17, 2008 | 10:52 AM
4rnnr33's Avatar
ya on the earlier ones you still have to cut the support
Old Aug 18, 2008 | 07:26 AM
jskijoe's Avatar
Thanks for the feedback. You're right, so you guys think I'll have to weld that whole portion or just bracing it will be sufficient?
Old Aug 18, 2008 | 08:00 AM
deathrunner's Avatar
I removed a bracket kit. Granted, I did not install bj spacers or a body lift. I definitely appreciate the lower stance on and off road.
As for the cut mounts, mine was very minimal. I only lost one bolt hole on each side.
Either way you go, I recommend getting a weld on truss for the rear. Sonoran Steel and Total Chaos make good ones. Mine was custom made locally.
Don't worry about the cut parts, just weld in a truss, you need it anyway.
Old Aug 18, 2008 | 08:55 AM
elripster's Avatar
I had a bracket kit and will never run one again. I had to cut one tab on the front of the IFS by the diff if memory serves. It could be easily remade and welded on.
The lower CG improves suspension flex and you don't have to even give up the 33's if you don't want.
Frank
Old Aug 18, 2008 | 05:18 PM
jskijoe's Avatar
I'm glad you chimed in, I've actually seen your truck in action a couple of times and if yours can handle it, I'm sure that mine will then. I also remember the deathrunner from the times I would do side mechanical work for Jim a few years back. Glad you didn't sell it(assuming you didn't), you had a lot into it and it looked like it did everything you wanted.
Mine I think is only missing a bolt hole on only one side (2 flanges) but I'm sure I can get it reinforced.
I was thinking of doing the 32's just for speed. It will be even better with the 3.4 under the hood too. If I'm gonna go faster, I think I wanna be lower on road and off you know...
I like the idea of more flex, how does that translate from being closer to the ground?
Thanks again guys for the comments.
kazuya2416
Apr 5, 2024 02:17 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
toyoterferdayz
Diesel Swaps
Jul 27, 2015 05:25 PM
crashburnoveride
Jul 10, 2015 06:39 AM
