rears up front with font leaf mix
Old Jul 11, 2009 | 09:47 PM
94sasyota's Avatar
hey guys i was just searching for this and really couldn't seem to find what iam looking for. i want to see if i can mix the stock pack up front off an 85 and mix the stock rears together and make about 3in of lift. i already have 5in shackles in the front.
Old Jul 15, 2009 | 12:35 PM
94sasyota's Avatar
bump for me no one here has any info on this should i just take the packs apart and mess with different combos
Old Aug 4, 2009 | 08:55 PM
Jager's Avatar
I made my packs out of Isuzu rears for the rear of my yota and then took a 3" lift pack apart for the front. I used the bottom three of the Isuzu pack and bolted them to the top two of my rear yota pack. I think I netted about inch and half to two inchs. The only reason Im telling you this is I think youll have better luck getting lift from a spring under vehicle. They have more arch to begin with.
Old Aug 4, 2009 | 09:01 PM
drew303's Avatar
You can mix/match springs and easily get 3" of lift from a rear up front. My buddy runs rears upfront right now and he's getting 3-4" of lift abouts. Works really well to (ie flex's great)
I went with 3" TG springs, and I sit about the same height as his rig and flex just as well but his springs were free lol
Old Aug 4, 2009 | 09:42 PM
shaw_j's Avatar
I am running RUF right now.
I combined springs from a 79 pickup and an 88 Runner. With my 5" front shackles I have netted ~ 3-4" of lift.
Perfect height for what I wanted.
The trick in your case is to cut them to the right length... Trial and error basically
Old Aug 4, 2009 | 09:52 PM
4Crawler's Avatar
Biggest issue is that the front leaves are essentially flat, very little arch to them, so you won't get much flex from them unless you have them re-arched at a spring shop.
Old Aug 4, 2009 | 10:09 PM
94sasyota's Avatar
i wounder if i have a small lift on the front of mine. they have a small arche. should i be able to clear 35's with a 5in TG shackle.Just got this truck about 7 or 8 months ago.
Old Aug 4, 2009 | 10:24 PM
algranger's Avatar
Heres my front pack top to bottom
1- stock rear main leaf
2- stock rear second leaf
3- stock rear main leaf cut to fit
4- stock rear second leaf cut to fit
5- overload (to keep from "w-ing" them over)
Sits like this
Old Aug 4, 2009 | 11:45 PM
4x4YOTA's Avatar
mine is
1st 82 rear main
2nd 82 2nd
3rd 82 3rd
4th 3"lift front rancho 4th
and with my sky boomerang shackle I get about 3" of lift
Old Aug 5, 2009 | 09:33 AM
shaw_j's Avatar
1. 79 main
2. 79 2nd
3. 88 3rd (79 3rds were snapped)
4. 88 main
5. 88 2nd
6. 88 4th
Works great
Old Aug 6, 2009 | 07:35 PM
94sasyota's Avatar
So i wonder if i have a small lift then? Should i be clearing 35's with just a TG 5.0in shackle. Also do you have to get a new spring hanger or can you use the stock ones?
Old Nov 4, 2009 | 01:35 PM
81yotalove's Avatar
i know this thread is a few months old but i was searching about ruf, so to you first gen pickups or anyone that knows a few questions, my front stock springs are sagging really bad and i was also looking for a little lift for now till i can really do what i want with the suspension. so what all did you have to modify to fit the rears up front on our first gen pickups? and how do they ride?
thanks in advance. and i appreciate any feed back!
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
