Rear coilovers, 3rd gen?
Old Jul 28, 2004 | 06:19 PM
Mad Chemist's Avatar
Just a random thought. I realize the rear suspension flexes pretty good already on 3rd gen 4runners, but would there be any advantage to switching over to a coilover setup? I suppose you'd still have to worry about driveshaft/skid plate interference... I'm just thinking out loud.
Old Jul 28, 2004 | 06:33 PM
Cebby's Avatar
I don't think you'd gain much without reworking the link setup (longer) and cutting holes in the cargo area for attachment points for longer coilovers shocks. Maybe a longer slip joint on the D-Shaft too?
Old Jul 29, 2004 | 05:52 AM
Yeah, I think you're right on those points, mostly just thinking outside the box since guys have begun switching to leafs in the back.
Old Jul 29, 2004 | 07:08 AM
NCSU-4runner's Avatar
generally speaking leaf springs are the easy way, and are proven to work. The coilovers would take alot more planning and research. Soemday i'd kinda like to do F/R coilovers cause they are just so "bling"
Old Jul 29, 2004 | 12:54 PM
Cebby's Avatar
Originally Posted by NCSU-4runner
The coilovers would take alot more planning and research. Someday i'd kinda like to do F/R coilovers cause they are just so "bling"
You and me BOTH!!!
Old Jul 29, 2004 | 03:36 PM
Flygtenstein's Avatar
There is no real reason to do this or practical way to do it on a rig that has a rear compartment that is closed.
Linked buggies or pickups are pretty straightforward because you can hack away. The correct geometry will go farther with regular coils.
Old Jul 29, 2004 | 05:19 PM
WolfpackTLC's Avatar
Very, very BLING. Mostly pointless...
Only benefit to a coilover I can see immediately is the ability to run a tender spring.... those rock!
Old Jul 31, 2004 | 04:50 PM
BruceTS's Avatar
Trying to fit coilovers underneath is quite difficult and you won't achieve that much travel unless you cut through the bed. Separate shocks and springs is a better route.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
noahstancik
Jul 17, 2015 05:38 PM
Vargntucson
Jul 4, 2015 12:15 PM
