Is the rear brake line for the pickup needed in 3"?
Old May 4, 2005 | 09:26 AM
baileymoto's Avatar
Is the rear brakeline addition for a 3" lift needed for the 96+ 4x4 pickup?
Old May 4, 2005 | 10:01 AM
4Crawler's Avatar
Maybe, maybe not. Depends a lot on how the lift is done and how much droop the rear springs get. If you are using an AAL for all/most of the lift, then probably not, since the AAL gains lift mainly by increased spring rate (i.e. the springs compress less for a given load) but does not provide much more in the way of axle droop. I ran 3.5" lift on my '85 and the rear brake line was fine. You will need a relocation bracket for the LSVP (proprotioning valve) though:
http://www.4crawler.com/4x4/ForSale/...l#OrderingInfo
Aleeex_u
Jun 5, 2016 06:52 PM
cchinny
Jun 25, 2015 08:11 PM
shepsyota
Jun 25, 2015 08:36 AM
HALMAN
Jun 14, 2002 09:02 PM
