Panhard Rod - Extend or Drop Bracket?
Old Mar 2, 2007 | 09:17 AM
Mojo_Risin's Avatar
I'm gong to be putting on the LC coils and shocks in the next week and am not sure whether to have a drop bracket made or just have them extend a my current panhard rod (if that's even possible - not sure what it's made out of). Is one better than the other?
John
Old Mar 2, 2007 | 10:36 AM
tc's Avatar
tc
Drop is probably technically better, it's better to have the angle lower so as the bar swings, the end doesn't move side to side as much.
The rear of Molly's truck (stock links, LC coils, panhard drop) is flexy enough that the way the panhard makes the axle shift is a real problem. The truck is not as stable as it could be.
After driving hers and seeing Flygtenstein's in action, when I lift mine, it's getting a triangulated 4 link in the back. (But then, I already have the gas tank out of the way...)
Old Mar 2, 2007 | 01:52 PM
Bill's Avatar
See, I've heard this both ways. Dropping it doesn't allow as much side to side movement, so keep the axle centerd better.
Extending it lets you retain that same pivot location, so doesn't inhibit your axles articulation.
thoughts?
Old Mar 2, 2007 | 02:18 PM
Mojo_Risin's Avatar
Ric, what rear lift do you have again? I've never had issues with mine either - but with the longer LC shocks I'm going to install - I don't wan't to have issues with the driveshaft hitting the gastank skid. I assume you've never had this issue?
John
Old Mar 2, 2007 | 02:57 PM
KyleT's Avatar
i have one of steves first drop bars, I have bent something and the driveshaft and gas tank get friendly too often. Im going to try to get it on a lift here before i leave work today and see what moved, i cant tell crawling on the ground...
Old Mar 2, 2007 | 03:09 PM
frodin1's Avatar
I just put the LC's on today and all is good. I'm going to leave well enough alone. That way if I want to put it back it'll only take a couple hours. Of course I did do this for tow purposes. I think it's going to work well.
Old Mar 2, 2007 | 05:06 PM
sschaefer3's Avatar
I think Steve D says it all:
https://www.yotatech.com/forums/f2/update-suspension-install-107290/
https://www.yotatech.com/forums/f2/pan-hard-bracket-adjustable-bar-question-105307/
Luvmeye22re
Aug 4, 2015 03:53 PM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
pyramid
Jul 30, 2015 10:05 AM
coffey50
Jul 28, 2015 10:55 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
