OEM Hitch Flip = 5 Deg Better Departure Angle - Pics!
Old Nov 9, 2003 | 12:18 PM
transalper's Avatar
Thumbs up OEM Hitch Flip = 5 Deg Better Departure Angle - Pics!
A recent posting inspired me to do this mod to my own rig. My departure angle improved by 5 degrees in 45 minutes!
Write-up with lots more pics: http://www.geocities.com/transalper/hitchflip.htm
Old Nov 9, 2003 | 01:10 PM
scott.475's Avatar
That's a great idea, may have to do it myself.
Old Nov 9, 2003 | 02:10 PM
transalper's Avatar
Close-up comparison:
Old Nov 9, 2003 | 02:26 PM
UKMyers's Avatar
Great mod! I just added a Drawtite hitch for towing and I lost a TON of clearance. It's really noticeable back there because I was so used to not having a hitch at all. I couldn't do this mod because of the design of the hitch so I guess I'll just drag it around with me.. the bumper thanks the hitch at least it isn't taking all the abuse anymore.
Old Nov 9, 2003 | 05:28 PM
midiwall's Avatar
Yeups... I did mine a couple of weeks ago:
http://www.midiwall.com/4Runner/hitch.html
I just got back from a trip to meet Dr. Z and RidgeRunner - I think you'll be seeing other folks do this mod soon.
Kudos to "protech03" for the original thread: https://www.yotatech.com/forums/show...threadid=19606
Old Nov 9, 2003 | 06:03 PM
Ric's Avatar
Ric
Banned - User requested
sweet
nice,, but i cant do that, my hitch is a one peice, darn the luck, i know 5 degrees isnt much, but every little bit helps untill i cant get the custom bumper.
Old Nov 9, 2003 | 06:32 PM
Bob_98SR5's Avatar
Guys,
Looks good. Mark, your poor hitch has sure taken a beating. Are you going to sand it down, prime and paint over it?
Also, I like what Transalper did to protect the edges. Transalper: will regular spray paint work? Though rust is not a big problem here in L.A., what do you guys recommend to protect the edges?
Bob
Old Nov 9, 2003 | 08:32 PM
OneTrickToy's Avatar
I know that most people here have Runners. But for those with trucks, you can get one that sits at the same height as the frame, and the receiver sits right behind the license plate. All you need is a hinge for your license plate. The downside, the drawbar needed, one that is long and has a major drop, is very expensive. The right one for my truck is around $60.
Old Nov 9, 2003 | 08:35 PM
midiwall's Avatar
I've thought about it, and I should. I was looking at it this weekend when showing Dr Z. and RidgeRunner, and we all kinda' agreed that a) it really has taken a beating, and b) it shows it.
The biggest problem for me is getting it ground down. I don't have a real grinder, so it can be a bit of $$$ and/or work to do. it's hard to get the feel of just how deep some of those divots are.
I liked that finish idea as well. The edge of where I cut out my bumper is already showing surface rust... Short of gluing that strip in though, I'd figure that it may end up popping out as things get dragged across it. It certainly looks nice.
I'll end up at least sealing the edges of mine with primer and poly...
Old Nov 10, 2003 | 03:59 AM
transalper's Avatar
Guys,
Bob
Spray paint may work. A better option would be applying some silicone before adding the edge trim. I will likely end up gluing on the edge trim just to be safe.
Major kudos go to Protech03 for inspiring a lot of folks to do this mod!
Old Nov 10, 2003 | 08:46 AM
This mod is sweet! My hitch always drags when I'm wheeling.
Unfortunately, I have the 1 piece hitch that comes on the '99+. Does anyone know if the older hitch will bolt in? Thinking about trading someone so I can do this mod...
Old Nov 10, 2003 | 09:41 AM
Ric's Avatar
Ric
hitch
thats a sweet mod, but wont work on my, BUT im wondering, IF there is a hitch that would fit, across the frame, up under the bumper ? id be happy to cut out the hole like done here, any ideas ?
Ric
Old Nov 10, 2003 | 09:54 AM
rimpainter.com's Avatar
U-haul sells hitches that mount flush against the bumper.
Old Nov 10, 2003 | 10:05 AM
transalper's Avatar
Everything I've seen says the 96-02 hitches are interchangable. If you are considering a swap it should be easy to measure the dimensions just to be safe.
Jcrawl94
10
Oct 24, 2015 04:34 PM
defrag4
Jul 31, 2015 10:50 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Edionne13
Jul 9, 2015 01:59 PM
