No more BJ Spacers
Old Mar 1, 2007 | 07:25 AM
  #41
elripster's Avatar
Originally Posted by Rcross
The last time I had to give the guy clues how to use the machine, and I have never used one before.
Ditto! It really is too easy to do this ourselves especially given the frequency if you wheel a lot.
Well I'm off to install some BJ spacers on my new-to-me 94 4Runner.
Frank
Old Mar 1, 2007 | 08:05 AM
  #42
CJM's Avatar
CJM
Look at it this way, your truck isnt aligned you want your cash back period...
I usually go to STS and they always do a very good job, after all they have a real alignment tech on duty and not some moron. I know how to use the hunter series and their alignment rack, its not to hard to do-however most techs just barely get it into spec and say your good to go-last place I had them dot hat I said no-you get it closer to spec or I dont pay you! Barely in spec is not what I am paying 50+ dollars for!
Old Mar 1, 2007 | 08:33 AM
  #43
AxleIke's Avatar
Mudbutt isn't making anyone rich. Hes just a concentious guy, and he knows his stuff.
His point, i think, is that if a person knew what he was doing, then an alignment with a machine can be even more accurate than a hand done alignment. Not that a hand done alignment isn't pretty accurate, but a square is only as good as the ground you are sitting on.
As for saving money, i hear ya. I think that is a valid point for most people. considering most alignment guys don't know jack, its a pretty big risk. But if you find the right one, it can really be worth your money.
Old Mar 1, 2007 | 08:44 PM
  #44
elripster's Avatar
If you find a good shop that is a bonus but it sure feels good to save the dough. I did the spacers and alignment today and the truck rides better and goes straighter so I'm happy. 50 bucks saved is 50 bucks earned.
I didn't think to add about flat ground, you do need to find it. Cement will self level but years of trees, etc... can change that.
Frank
Old Mar 1, 2007 | 10:01 PM
  #45
Rcross's Avatar
Well I have issues about the flat ground, my driveway looks as if it was leveled by Stevie Wonder. Its not that it isn't level but has a lot of waves in it. To solve that issue I have a length of 1/4 plate that is wide enough for me to park both tires on. I will make the measurements, make adjustments, and then back up about 8 ft then pull back on the plate, rinse and repeat.
As for as the toe in I know a certain degree of toe in helps it track straighter. After I get the front tires dead straight I will make about 1/8th a turn in on each side. The toe in is just barely noticeable using the string and it drives just as straight as my wifes Heep Grand Cherokee ( I know its not saying much)
Old Mar 2, 2007 | 08:59 AM
  #46
86Original's Avatar
Something no one has mentioned is that the torque spec on the cam adjuster nuts is about 200 ft-lbs. I have a ~14" long 1/2" ratchet, which means about 175 lbs at a perpendicular to the lever arm of the ratchet in order to get it in spec (my torque wrench only goes to 150 ft-lbs). How many techs actually get that within spec?
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
crash813
Sep 27, 2015 07:15 AM
