New Demello Front Skid (Pictures)
I ordered up a skid plate to replace the factory one after getting the front bumper done. The factory skid mounting was cut off to reinforce the front frame but could have been welded back in so I could use it. I decided to get a beefier skid plate in its place.
I also finally got around to painting the white areas exposed by the front bumper. Looks nicer now.
I got it yesterday and so I thought I'd share.
From the rear of the plate
Rear looking forward
Front looking rear
You can't really see it in the pictures but it's got some small tubing but really thick walls that brace it all and it's really stout. The tube frame is attached at the differential bolts, this is the reason I got rid of the diff drop spacers which I posted here about, and the tow hooks at the front. Then the skid bolts are attached to the tube frame.
Front looking rear
Originally Posted by Scofco
Needs black paint and some kind of white logo on it
Originally Posted by sc0tty
sweet... how did you choose to deal with your blinkers when loosing the lower valence?
Originally Posted by Darx
They were relocated to the corner lights. Drilled a hole into the bottom of the corners and fit them in there. Works great.
Originally Posted by Birdman
That looks real nice Matt. I like the blacked out grill and the painting you did. It reall finishes it off. Looks kinda mean.
I'm wondering if that paint will hold up if I do the aluminum plate covering the radiator.
