New coils, new problems
Originally Posted by byron4
i also have the OME 901HD's(not installed yet) for my 93. so i need...
- coils
- panhard drop bracket
- brake porportioning valve drop bracket
- extended brake lines
anything else.......... now im wondering why i didnt go with downey.
thanks
- coils
thanks
As many of you know I sell the OME kits. I also use them on my '91 4runner. I am running 901HD Springs, OME Shocks/Steering Stabilizer, SDORI Ball Joint Spacers, Downey Pan Hard Bracket and the Downey Rear Control Arm Truss. I made my own BPV bracket and still have stock brake lines. I have wheeled this setup and have had no issues with Brake lines, drive shafts or BPV not working. Alot of the items mentioned are great to have but, IMO not an absolute must have to get started. I am sure others have their opinions of what is needed and I can't say they are wrong. Our Kits do not come with the Downey Brackets. I would suggest you look at these items or something similar. You will find as you go along other items that will make your Off Roading experience more enjoyable and improve your ability to manuver harder trails. The next expense most of us face after the basic lift are Tires/Wheels and the need for protection (sliders, bumpers, winch etc). We all can agree you can go as far as your wallet will let you. We made these kits as a Basic setup to get you started. I hope this helps...........
Originally Posted by callmej75
I got the 901's and don't have any of the above. Brake lines have plenty of play because the swaybar keeps it from hyperextending them. Brakes work good. Hate the wheel sticking out farther on the drivers side but the driveshaft hits nothing. It works good as it is...but it don't work good with stock shocks. I learned the hard way by breaking the weld on the shock eyelet.
I have to believe the OME901s give you a lot less lift than the cruiser coils. I have cruiser coils and there is NO WAY the stock rear brake line would work (off road that is, it may work on the street but if you flexed the rear axle with longer aftermarket shocks, the brake line would be lucky to survive). While we're at it, the brake line that needs extending is the one that runs from the top of the rear diff to the fitting near the brake proportioning valve that is mounted higher up near the frame cross member. The individual brake lines that run into the rear brake drums are fine. Check out these threads for more info on Cruiser Coils and rear lift options for the 2nd gen 4Runners.https://www.yotatech.com/forums/show...r+shock+thread
https://www.yotatech.com/forums/show...6&page=1&pp=25
https://www.yotatech.com/forums/show...9&page=1&pp=25
#25
What is the Rear control arm truss? I have looked at a lot of the second gen lift threads and I may have overlooked that, but what does it look like? I get the idea, it probably beefs up the control arms, but a pic would be cool. I can't wait till tax time, gather the rest of the lift parts and redo the front end.
#26
http://www.downeyoff-road.com/Suspen...ents/index.htm
Scroll down to IFS truss....it goes between your lower control arms to keep them from knocking your alignment off...strengthening them.
#27
This is a rear Truss compliments of Deathrunner here on Yota Tech.
#28
Originally Posted by strap22
He wanted to know what else he would need to make the OME's work...The other options available out there all have their place too.
#30
Little off subject but nice 4unner hydrohead!
Bill
#31
Originally Posted by PAhydrohead
Ooops, you're right Strapp, the rear lift setup I have is probably considered the next step beyond what you guys are discussing. Hope I didn't confuse everybody
#32
Hey thanks, while we're highjacking, how do you like your 40 series flowmaster? Does it resonate inside the truck so its hard to hear the radio? I have a 50 series and it sounds great with my headers (at least it did until the tailpipe connector cracked off the header, now all I can hear is..ahh noise) I'm wondering if the 40 series would get to be annoying on a long trip.
Bill
Bill
sandyota
Feb 4, 2021 11:16 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Vargntucson
Jul 4, 2015 12:15 PM
