need help choosing shocks
Old Apr 11, 2007 | 05:07 PM
20005spd's Avatar
front lift install problem
i was installing 2.5" spacers in the front of my 2000 4runner and the top shock nut is rusted and i couldnt risk ruining the shock because my truck cant sit on a lift at work. not to mention itll be a pita to get the spring and spacer to compress onto that old worn shock . so should i get tundra shocks? i can get a deal at toyota but im not sure if the stock spring works with it or what yr to get if it does work. any ideas?
heres a pic of the shock, i broke the top part where you are supposed to hold the shock from spinning.
Old Apr 11, 2007 | 05:26 PM
20005spd's Avatar
bump
Old Apr 11, 2007 | 05:32 PM
Ringmaster's Avatar
Warm the nut up with a torch, it'll break free.
Old Apr 11, 2007 | 05:34 PM
20005spd's Avatar
i was going to but right under the nut is the washer than a rubber insulator, 99% sure ill cook that rubber. id rather get new ones at this point. will the tundras work with stock springs?
Old Apr 11, 2007 | 06:12 PM
20005spd's Avatar
bump
Old Apr 11, 2007 | 06:32 PM
Sonofmayhem's Avatar
i dont think so i think they are too long. go over to ttora and buy some newer stock ones, or even stock tundra coilovers.
Old Apr 11, 2007 | 06:40 PM
20005spd's Avatar
i just bought spacers im not buying a entire coil/shock setup. i just need shocks. i just need to know if stock springs work with it. everything else will im pretty sure of.
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
dirk89
Oct 1, 2015 05:15 PM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
