movin on up
movin on up
this is how my 4runner currently sits:
31's, stock gears, stock height, ez-locker rear, truetrac up front, 4.7 gearset in the case. i was hoping to be able to swing an SAS, but my engine needed a rebuild and that ate that budget. but i need new tires this spring anyway so.....
waiting to go in:
4.88 yukons for the rear
and a used 4.88 factory set for the front.
also a set of balljoint spacers and i got a stick of scrap 2" diameter polyetherimide rod from work, and cut it into a 1-1/8" body lift.
working out a deal on some used 33" mtrs so, now its just a matter of getting everything put together!!
waiting to go in:
Originally Posted by KING
31's, stock suspension, stock gears with locked ends and a crawler box?
I thought I would never see this day.
update: got the balljoint spacers in and the front diff regeared.
got the used MTRs mounted:
above you see one of the old 31s standing next to it for comparison.
since im using 12.5" wide tires on the stock 7" wide rims, and stock backspacing, the tires wouldnt clear the UCA with the balljoint spacers installed. to remedy this, i installed some 1.5" wheel spacers:
sure the front is wider now, but it isnt really noticeable, and the hub is better protected now:
balljoint spacers are from http://www.sdori.com
colsoncj, where are you located right now? my club is heading to rockport, IL on apr 23, would you be interested?
if you do a search, you will find all the info you could ever want on the balljoint spacers.
if you are talking about the wheel spacers, they have the same effect as wheels with less backspacing, but some people have had them loosen up and wheels have even fallen off while driving, thats why i used the locktite
well, got everything together today finally, did the initial gear break in, then changed the fluid and drove it 180 miles to school. ill try to get some pics of the finished (for now) product.
I don't think we'll be able to make it to IL in april, however if you wanna come wheeling this weekend we're going to a nice 4WD park in Disney OK sat and camping until sun, you're welcome to join!
heading down to russ hogan's place i take it? ive never been down there, although i have always wanted to go.
this weekend i wont be able to. i dont have my camping equipment with me and im short on cash, so it will have to be another time.
