LSPV? bracket question
Old Nov 7, 2007 | 06:49 PM
byron4's Avatar
ive been searching on ways to rid my 4runner of the aweful gas tank skid to drive shaft grinding noises i got when i installed my OME 901 coils. i ordered a panhard drop bracket from 4crawler to hopefully fix the issue. anyway, during the search i kept reading i needed to do something to my LSVP?? bracket. first of all i dont even know what that is. from what i gathered it's a brake proportioning valve or something to do with the brakes. is this a pretty important fix to do when installing the lift? ive got 33" tires as well so i would think keeping the brakes strong is a necesity for safty reasons. long story short... what is the LSPV bracket and what do i need to do (if anything) to compensate for the lift. can i buy this part or does it need to be custom made? (im not the handiest)
Old Nov 8, 2007 | 12:51 PM
4Crawler's Avatar
See:
- http://www.4crawler.com/4x4/4R_suspe...ortioningValve
http://www.4crawler.com/4x4/ForSale/...l#LSPV_Bracket
In short, raises the sensing rod on the rear brake proportioning valve to compensate for the lift. Why? Sensing rod operates the LSPV telling it to lower rear brake pressure when there is less load on the rear axle to prevent the rear brakes from locking up. How does it do this? Ride height. If the ride height is high, that indicates no weight in back, thus lower rear brake pressure. Ride height low = lots of weight in back = higher rear brake pressure. Problem is the LSPV can't tell if the higher ride height is due to no weight in back or due to a suspension lift. Raise the sensing rod an amount equal to the lift height and all is back to normal.
Old Nov 8, 2007 | 02:50 PM
byron4's Avatar
4crawler... thanks for the info but i havent been able to access your website all day today
Old Nov 8, 2007 | 03:26 PM
4Crawler's Avatar
Web site is up and running. What sort of error are you getting?
A leaf spring type bracket below:
Installed:
On the coil spring axles, the LSPV bolts are side by side instead of vertical, but the idea is the same.
Old Nov 8, 2007 | 05:40 PM
byron4's Avatar
it just says they page cannot be displayed. ive tried links, going through google, etc. nothing works. your pictures also do not work.
Old Nov 8, 2007 | 08:04 PM
4Crawler's Avatar
Sounds like you have something blocking the site then.
Old Nov 9, 2007 | 08:41 AM
byron4's Avatar
it let me get on previously... heck i just ordered a panhard drop bracket yesterday or the day before off of your site. on that note how long do those take to ship out?
Old Nov 9, 2007 | 08:51 AM
4Crawler's Avatar
Usually ship the same day, 2-3 day typical shipping time for priority mail. You should have the tracking number via e-mail.
shisha1999
Aug 14, 2015 01:33 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
