Bolt-On or Weld-On D-Rings
Old Nov 9, 2007 | 02:05 PM
DIHOWARD's Avatar
my 03 4runner has no front end recovery points to speak of, so I got a pair of 11,000 lb bolt on D-rings. what grade of bolts are best?
some have told me that a grade 5 will shear and that grade 8 will give more because they arent as hard. should i have them welded as well ?
Old Nov 9, 2007 | 02:26 PM
SCYOTA's Avatar
Don't know what size bolts they are but I would go with grade 8. If they were designed to bolt on then I assume that if you use a grade 8 bolt in the correct size you should not have a problem.
Old Nov 9, 2007 | 02:30 PM
cubuff4runner's Avatar
They didn't come with bolts?
Old Nov 9, 2007 | 02:33 PM
1eye's Avatar
Go at least grade 8 if your using bolts. A better question might be, where/what are you going to fastening/welding them too? The only thing worse that a broken cable or tow strap coming at you is having the hook or D-ring joining it in flight.
Old Nov 9, 2007 | 06:41 PM
DIHOWARD's Avatar
bolt-on D-rings
no they didnt come with bolts, I'm going to drill the frame just behind and above the factory hold-downs. I may have those things cut off, they're useles. thanks for the hardware advice. once I get them on, do you think a quick tackweld or 2 wil help, or am I just wasting my time?
Old Nov 9, 2007 | 08:39 PM
elripster's Avatar
One thing about the hardware. Should you chose to stay with metric, it doesn't go by grade, it goes by class. In that case you would want class 12.9 which is a bit better than standard grade 8. If you picked up a class 8 scew, it would be the equivalent of a grade 5 and not very strong.
Frank
Old Nov 9, 2007 | 09:18 PM
1eye's Avatar
As elripster said. Use at least grade 8 or metric 10.9, if you can get your hands on them metric 12.9 about as strong as you can go in the civilian world. Just make sure they are bolted to something very strong [like the frame].
jerusry
Oct 19, 2015 05:28 PM
Poopshute
Mar 14, 2005 09:28 PM
delboy
Apr 9, 2004 12:08 PM
TDiddy
May 20, 2003 07:45 AM
