Lock Front or Lock Rear??
Old Sep 17, 2003 | 06:57 PM
Skydigger's Avatar
OK I've posted this a few places and I'm getting differing opinions.
Please hold off on the "lock both" responses.
I was talking to someone on Sunday and he mentioned that he put his one locker in front on his Toy. Aussie Locker's web-site also says that it is most beneficial traction-wise to put their locker up front instead of the rear if you only have one locker.
What do you guys think? Steering issues aside where's the better place for a single locker; front or rear?
Tks,
Warren
Old Sep 17, 2003 | 08:03 PM
data's Avatar
Senior Member
Lock the rear. I had a friend that had his taco locked only in the front and he broke cv's all the time. My vote is for the rear.
Old Sep 17, 2003 | 08:11 PM
Robinhood150's Avatar
He's solid axle.
Old Sep 17, 2003 | 08:25 PM
PoBoy's Avatar
Rear...there is more weight in the front so both front tires are usually on the ground more than both rears. Thus, a rear locker would help more.
Old Sep 17, 2003 | 08:57 PM
Skydigger's Avatar
thanks guys. Yep I'm solid axle.
But what about the weight transfer when climbing? The argument goes that when most of the weight is transferred to the rear traction up front becomes more of an issue/necessity and a front locker would then aid in 'pulling' you up.
Regards,
Warren
Old Sep 17, 2003 | 09:14 PM
Shane's Avatar
With what? If there's not enough traction for an open diff what makes you think a locker in front is going to help any? There will be very little weight on the front end, and both wheels will spin along with one of the rears. Definitely more usefull in the rear when climbing.
Or you could just lock both...
Old Sep 17, 2003 | 09:31 PM
Flygtenstein's Avatar
Lock the rear. Period.
Weight transfer climbing makes it logical.
Stronger components.
Steering, as in do you like it?
Will it be an auto locker or a manual? Do you use 4wd on the street?
Lock the rear or lock both.
Old Sep 18, 2003 | 05:32 AM
crawler#976's Avatar
I vote rear locker-
You'll be able to go more places in both 2X4 and 4X4 with a rear locker. Having the rear locked gives you almost as much traction in 2X4 as an open rig has in 4X4.
Old Sep 18, 2003 | 05:36 AM
jacksonpt's Avatar
Senior Member
It depends on the type of wheeling that you do. Rear lockers are well suited for loose steep climbs, front lockers are better suited for rock climbing. Either will help in "general trail" wheeling.
There's a good discussion on this very topic here. Might be worth your reading. FWIW... the discussion is among a mostly rockcrawling group.
Old Sep 18, 2003 | 08:50 AM
Skydigger's Avatar
Thanks for the input guys! and Jackson thanks for the link.
Warren
Old Sep 18, 2003 | 08:54 AM
rimpainter.com's Avatar
Lock the front and drive backwards.
Old Sep 19, 2003 | 02:23 PM
Mad Chemist's Avatar
Lock the side and drive around in circles....
Old Sep 19, 2003 | 03:23 PM
Skydigger's Avatar
How about I just lock the doors and don't drive it at all.
Old Sep 19, 2003 | 03:31 PM
Shane's Avatar
That's fine, just make sure you give one of us the keys on your way out.
Old Sep 22, 2003 | 01:10 PM
44Runner's Avatar
yep, that's about right...
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
toyoda8488
Jul 5, 2015 10:18 PM
