Lift blocks on Front
tc is correct in that the most probable fix is to cut and turn the knuckles and perches. however i have seen death wobble caused by loose steering and suspension components aswell as tire pressure. i've also seen a second steering stabilizer band-aid the problem. if you've already cut and turned it you should try moving the axle forward to get a better pinion angle. this wont fix the death wobble but will keep the 350 from blowing up u-joints.
I'm about to say the heck with it. I have 4 trucks,
99 ranger 2wd(daily driver)
my yoyo(weekend warrior)
77 F-100 351m 4x4(next project in line)
87 F-250 302 d60 rear (truck sittin on blocks lol)
Im really thinking about selling the yota and starting on the F-100. I just hate to give up after all the time and money i invested in it. So frustrating.
also have a 80 somethin s-10 body sittin in the yard about to put it on a k-5 blazer frame when i get time, but yeah i'm gonna buy a dual stabalizer first, then re-do my steering maybe theres a flaw in it somewhere i'm just not seeing. the 350 turbo's goin anyways, i cracked the bellhousing. TH400 is next to go in.
well i got shackles and drop hangers in the front and i cant seem to figure out why i still have death wobble, this is the why im asking the question. i figured maybe its the shackles causing the problem, I've tried everything i know. when i accelerate to around 35-40mph it starts violently shaking but when i power thru it, it goes away till i turn or brake. And i need the lift to clear both sets of my tires. And yeah i drive it on the road.
- http://www.4crawler.com/4x4/ForSale/Shims.shtml#FAQ1
I used to have bad DW at 35-40 MPH until I changed the caster angle about 1 - 2 degrees and it is gone now.
#27
so 4crawler is sayin i need to put shims under the leaves in the front, and it will fix 2 things, pinion angle and DW? thats what i got out of all that.
5* camber will likely fix everythng? Can i make my own shims or do i have i have to buy them?
#28
5* atleast. And it will hurt your pinion angle...alittle.
DW is, in my experiance, a combination of things causing a harmonic that builds on itself. bad or loose TRE's, loose knuckles, bad trunions, bad wheel bearings, tires, toe, caster, etc... all can contribute to death wobble.
#30
I found something guys, the bolt that runs thru the eye of my front leaf spring is alot smaller than the one that should be in there. when i take of or stop you can watch the leaf spring move ever so slightly forward and backward, could this be the culprit causing my DW?
#31
Anything that is loose can let any source of vibration up front grow due to resonance and if that goes on long enough, you get death wobble. But that may not be the root cause, but worthwhile fixing that to eliminate it as a possible cause.
#32
yeah and the centering pin doesnt REALLY keep your axle from moving front and back. If your axle is moving your u-bolts are loose. I check the torque on my u-bolts and steering arms regularly!
#33
on my drag link both ends have some play in them, and wheel bearing on passanger side aint bad but you can tell its startin to wear.
Other than that those 3 things are the only contributors i can find, other than my center link being a lil bent. Not to mention my front end could use a good alignment.
Wht you guys think?
Wht you guys think?
#34
Crank the drag link ends down as tight as you can get them, especially if it is a dropped drag link (S-shapped type):
- http://www.4crawler.com/4x4/4R_suspension.shtml#PhaseI
Fixing DW is basically a process of elimination, get rid of all the play in everything you can find and have a shop check the alignment (toe in and caster angle) and then check the tire balance.
#35
Wht you guys think?
Wht you guys think?
The TINIEST bit of play can start the chain. you need to post up pics of your truck and the suspension.
#36
As mentioned above - all you need for DW is one small thing to start the chain at the right frequency.
#37
in addition to the stuff you found (too small of bolt etc) are you positive your drop hanger is correctly mounted?..worn tires could contribute too...my 35's were worn, swapped them to the rear and no more wobble.
#38
the drop hanger is correctly mounted, but i want to go back cut it all out and redo it. I knotched the frame enough for a peice of squre tubing to run across welded it in, then attached my hangers that i built to it. I'm about to post some pictures, and i dont know how lol
#39
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
Vargntucson
Jul 4, 2015 12:15 PM
