Installing OME Front Now.. Question??
Old Mar 16, 2004 | 03:20 PM
SkyRat's Avatar
Question Installing OME Front Now.. Question??
I am installing the ome front shocks and springs (Thanks Brian and Shawn!!) my question is this... one spring seems a bit longer than the other, does that go on the drivers side like I have read about in the rear set?
Old Mar 16, 2004 | 03:21 PM
TDiddy's Avatar
Hmmm...that rule really only applies to the rears. How much of a difference are you talking about?
Old Mar 16, 2004 | 03:24 PM
SkyRat's Avatar
looks like only about 3/32"
Old Mar 16, 2004 | 03:34 PM
TDiddy's Avatar
Oh ok. Your choice then, shouldn't matter!
Old Mar 16, 2004 | 03:36 PM
SkyRat's Avatar
thanks...
Old Mar 16, 2004 | 06:46 PM
waskillywabbit's Avatar
Talking Stuff
Glad you got your stuff okey dokey George!
I wanna see some when you get done!
Old Mar 16, 2004 | 07:04 PM
hhog4dc's Avatar
you might want to put it on the drivers side since that is the gas tank side and on mine it is a little lower on the drivers side even with trim packer... just a thought...
Doug
Old Mar 16, 2004 | 09:34 PM
SkyRat's Avatar
I did put the slightly longer spring on the Drivers Side just in case. The install went pretty well. Because I have the Craftsman Spring Compressors, and the area they grab the springs with is pretty large I had to finesse the boot onto the shaft. The diff drop took hardly any time at all.
Quick take is that after just a drive around the block, the OME is really smooth. I was a bit concerned that it would be a bit too stiff, but it is way smoother than the stock stuff. I do detect quite a bit more body roll than stock, but that is just a quick evaluation. I will post a pic or two tomorrow and give a thorough review after Anza Borrego this weekend.
Thank you Brian, thank you Shawn.
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
