IFS Bumpstops
Old Jun 30, 2009 | 06:02 PM
blueyota38's Avatar
IFS Bumpstops
I realize there has been severel threads about bumpstops but i think i have something not said yet. I bought my yota and i has a 6 in lift. Somebody put 4in body lift blocks between the a-arm and the bumpstop making it bottom out real quick. I was just wondering if it would mess anything up if i took them off leaving the stock bumpstops in the stock position? I didnt know if it would travel enough to pull the cv axle out or anything. Thanks.
Old Jun 30, 2009 | 06:21 PM
tc's Avatar
tc
What kind of rig? What 6" lift? What size tire?
Pix?
Old Jun 30, 2009 | 06:31 PM
blueyota38's Avatar
Its not really a name brand its just blocks in the back and the regular stuff with no brand name on them. Its a 1994 toyota pickup daily driver/ trail rig. And 33/12.50/15 Maxxas Buckshot. And i dont have any pix but as of now the bumpstops are about a inch or two away from the a-arm and i really would like to have more travel in the front than that.
Old Jun 30, 2009 | 06:38 PM
jtruck79's Avatar
we pulle dthe bumpstops out of a friends 88 toy 6months ago way improved flex then we pulled front sway bar now he can rub fender with 6inch lift and 35's. has been wheeled hard and never pulled a cv apart yet. but if ur worried u can always cut urs in half and reweld together to shorten it. Have fun make friends....
Old Jun 30, 2009 | 06:40 PM
blueyota38's Avatar
So did his have body lift blocks on the bumpstops to?
Old Jun 30, 2009 | 06:53 PM
4Crawler's Avatar
Those would not be "body lift blocks", those would be placed between the frame and the body in order to "lift the body". What you are talking about are the bump stop extensions. You might try putting in a lower profile bumpstop or simply cutting down the stock bumpstops to shorten them and allow a little more travel. You do want the bumpstops to stop the suspension before it compresses too far and causes damage to itself or other components.
Old Jul 1, 2009 | 12:55 PM
blueyota38's Avatar
I am possitive they are body lift blocks and it looks like it was riged in other words. My buddy has the same blocks on his truck. i guess what i am trying to know is if i would be able to have the bumpstops in the stock location without the truck bottoming out and tearing things up? Sorry i didnt have this clear.
Old Jul 1, 2009 | 12:58 PM
4Crawler's Avatar
Well, they may be spacers of some sort, perhaps a recycled body lift block, but in that location they would not be lifting the body, only spacing the bump stop to match the lift. Maybe try cutting down the spacers a little to allow some more travel. And post a picture or two, might shed some light on the issue you are having.
Old Jul 1, 2009 | 01:36 PM
blueyota38's Avatar
ok ill try to get a picture on here of it.
Old Jul 2, 2009 | 06:16 AM
blueyota38's Avatar
Can someone talk me through on how to get a picture on here because i have been messing with my kodak easyshare thing for 45 min trying to get the pictures on here.
Old Jul 2, 2009 | 06:20 AM
yoder519's Avatar
go on photobucket.com and set up a free account. after you upload the pics, right click and copy the [IMG] code then paste it in a new post. welcome to Yotatech!!
Old Jul 2, 2009 | 06:40 AM
blueyota38's Avatar
thanks
Old Jul 2, 2009 | 06:58 AM
blueyota38's Avatar
Here we go i think.
http://s459.photobucket.com/albums/q...t=100_0822.jpg
It wouldnt copy and paste the picture so just go to that link and its a picture of it. Just dont mess with my stuff on there. Thanks
Old Jul 2, 2009 | 07:10 AM
4Crawler's Avatar
Looks like a normal spacer block from a bracket lift kit to lower the bump stop. You might try a slightly shorter spacer, for example if that one is 4" tall, try something in the 3"-3.5" tall range.
Old Jul 2, 2009 | 07:26 AM
Lumpy's Avatar
You need to copy the direct link and it will post.
Wouldn't that be for a IFS Drop bracket lift??? I have not worked on one of these but I have see a few. A body lift will not have these brackets on the bumper stops. You can raise the body 10" and not need these.
Old Jul 2, 2009 | 09:10 AM
blueyota38's Avatar
I know body lift doesnt need these but i have suspension lift only. where would you think i could get ahold of some of the smaller spacers.
Old Jul 2, 2009 | 09:14 AM
Lumpy's Avatar
I'm sorry, I do apologize, I could have sworn somewhere it stated that it was a body lift. I guess I miss read somewhere.
Anywho...I think the best thin to do is take them out can cut them down and re weld them. Just be sure before you cut them have it flex (I know IFS Flex...) and see how far it will travel and how much you need to cut out. Go slow and take your time and it you should be alright...should be.
Old Jul 2, 2009 | 09:18 AM
blueyota38's Avatar
Ok, i think what you read was that they were body lift blocks. Very missleading
Old Jul 2, 2009 | 09:20 AM
4Crawler's Avatar
Might try a local metal scrap yard or fabricator and see if they have some cut off scraps of rectangular tubing to could get ahold of.
Or if you can't find anything locally, I have some 3" tall stock that I could cut out a pair of spacers that you could try. Would run about $15 for the two spacers and $7.00 shipping.
Old Jul 2, 2009 | 01:33 PM
blueyota38's Avatar
Thats nice but i beleive i am going to be able to find some local. Or if that dont work cut mine. Thanks anyways.
