How stiff are daystar rear-add-leafs?
Old May 4, 2005 | 10:15 AM
baileymoto's Avatar
How stiff are these actually? Pretty cheap at roughly $65 per set.
Any thoughts?
Old May 4, 2005 | 06:49 PM
Alin10123's Avatar
Adding a leaf will make your ride harsher.
What you might want to do is add air bags in the rear. This way you can control the ride height when you have weight back there. Plus it doesn't decrease the comfort.
Old May 5, 2005 | 07:52 AM
03TRDBlack's Avatar
Yeah, except airbags are way more expensive and time consuming to put in. Not to mention the installation of an air compressor. I would look into shackles if you want to keep the stock ride. Otherwise you'll have to replace the leafs with some others that will also be fairly expensive.
ZGjethro
Jun 7, 2017 11:04 PM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
fountain
Sep 28, 2015 03:04 AM
Patrick1976
Sep 15, 2015 11:33 PM
