how easy is it to change gears by yourself?
Old Nov 14, 2003 | 08:01 PM
INsr5runner's Avatar
I mean, is pulling the third member all that hard?
the only thing I see that would be really difficult is the front diff
Old Nov 15, 2003 | 05:47 AM
Todd E's Avatar
The rear diff is easy (done mine a few times). Disconnect driveshaft and brake lines, slide axles out and support (don't let them rest on the seals, you will damage them), remove 3rd. Reverse process to install.
I don't have a front one, but from what I hear they are heavy (like 80 lbs) but relativly easy.
Todd
Old Nov 15, 2003 | 06:07 AM
Shane's Avatar
Rear is about an hour of work. Like Todd said disconnect brake lines, remove 4 nuts at either end of the axle housing and pull brake/axle assemblies out, remove thirdmember.
The IFS front is a little more involved, but not that bad. After you get the truck on jackstands you connect your work lead to a good clean spot on the frame and then proceed to cut the diff/suspension brackets off with the plasma torch.
Old Nov 15, 2003 | 06:13 AM
hahaha I know! I can't wait to chop it off! I'm in the process of finding a new diff for it though! one that fits a d44
smthwsn357
May 1, 2024 07:28 AM
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
