HELP with Leaf Spring Removal!!!
Old Sep 22, 2005 | 10:35 AM
ozzfan1JC's Avatar
Question HELP with Leaf Spring Removal!!!
On my 84 yota, I am trying to replace my rear leaf springs, and I have everything removed except for the front hanger bolts. I have removed the 2 retainer bolts on the outside, and the nut from the inside, but this bracket/bolt will not come out... is there something I am missing, or are they just probably frozen up??? Any help would be appreciated...the saw is my next option...lol.
Old Sep 22, 2005 | 10:39 AM
4Crawler's Avatar
Likely the pin is rusted to the inside of the rubber bushings. One option is to heat up the pin with a propane torch to see if you can soften the rubber's bond on it. Otherwise, try wedging a flat bar under the edge of the pin to try and lever it out. Also, repeated applications of penetrating oil to soak in and soften the rubber will help if you have a few days to let it work.
Old Sep 22, 2005 | 11:04 AM
Yoda's Avatar
We had to cut them off with a saws-all. Cut them outside the hanger, then slightly spread the hanger and drop them out. NEVER was able to get the stub out of the spring.
Old Sep 22, 2005 | 11:07 AM
Intrepid's Avatar
I had to do the same thing, cutting them out sucks, I would suggest large doses of penetrant and massive amount of prying and hammering.
Old Sep 22, 2005 | 11:14 AM
snap-on's Avatar
gas axe
Old Sep 22, 2005 | 11:30 AM
dwh91102's Avatar
heat and a bfh
Old Sep 22, 2005 | 03:57 PM
fatdudesurfin's Avatar
cut it off
you can fit a 7" circular saw on the forward hanger
using a bfh might bend the forward hanger
Old Sep 22, 2005 | 04:42 PM
bruzer1123's Avatar
4.5" angle grinder with cutting wheel...
Old Sep 22, 2005 | 05:33 PM
Remi's Avatar
Or you can do what I did.
Use a 2 jaw puller to push out the pin half way (make it a pin by cutting of the head of the bolt). This will streatch the rubber bushinmg with the pin even that far. Than you put a few drops of "goof off" or any tar remover on the bushing where it bonds with the pin. This will almost instantly break the bond between the pin and the bushing. Than you repeat by pushing the pin out the otherside.
Old Sep 28, 2005 | 05:17 PM
ozzfan1JC's Avatar
Thanks
Thanks everyone, and combination of heat, PB blaster, sawzall, bfh, and a 10 ton press got her done lol.
88sasturbotoy
Jan 30, 2026 01:57 PM
nvdesertrunner
May 11, 2020 08:18 PM
4x4-runner
Apr 18, 2017 09:08 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
Greene916
Aug 10, 2015 01:45 PM
