Heavy Duty cv's
Old Apr 1, 2005 | 04:03 PM
WATRD's Avatar
Originally Posted by ravencr
So, are you saying that you never broke once you put these one's in, even locked and 35" tires?
Chris
Yep, that is what I said in my first post in this thread
I was breaking the stock ones pretty regularly with the front locker and 35's, but once I put those on, I didn't break anymore until I did the axle swap
Old Apr 1, 2005 | 05:52 PM
ravencr's Avatar
So, how long did you run them and did you wheel it very hard I presume?
Chris
Old Apr 1, 2005 | 06:00 PM
Shane's Avatar
Originally Posted by deathrunner
Porsche cv's are awesome and far superior. I would liek to run them one day. About 1,00 a pair. They fit on your stock axles.
They have six balls instead of 3.
I'm assuming you're talking about the CV joint and not the other "tulip" joint which has 3 rollers, not balls. The Toyota outer joint, the "CV" joint, does indeed have 6 balls, not 3.
Old Apr 1, 2005 | 06:44 PM
WATRD's Avatar
Chris
I ran them for a year or so, maybe a bit longer, on the same trails that were breaking the stock shafts.
Old Apr 2, 2005 | 04:42 AM
  #25
ravencr's Avatar
That's pretty awesome! Thanks for the info!
Chris
Old Apr 2, 2005 | 04:48 AM
  #26
callmej75's Avatar
yeh watrd....good info.
Old Apr 3, 2005 | 08:43 PM
  #27
Napoleon047's Avatar
you could always consider sending your stock outer CV's to bobby long (longfield) to have them heat treated and cryo'd. i dont see why it wouldnt be the same price as 2 birfields. i just moved up in tire size, so if i start breaking them regularly, im going to give that a try.
MichaelKLerner
Oct 27, 2015 07:18 PM
Obmi
Oct 4, 2015 11:30 AM
83
Sep 27, 2015 04:13 PM
briholt
Sep 20, 2015 10:26 PM
sonorn67
Sep 19, 2015 05:39 PM
