half shaft removal Question
Old Sep 29, 2003 | 07:51 AM
oldsub86's Avatar
Question half shaft removal Question
Is there a trick to removing the half shafts? I have the studs out of the hub flange on the inner joint of the driver's side joint but can't get the hub flange to clear the diff extension flange so that I can pull the half shaft out to the inside.
Old Sep 30, 2003 | 06:52 PM
jx94148's Avatar
Let the suspension droop all the way and you can get it off. Also you can use a brass drift to pound the studs out of the flange and it will slip out.
This is kind of a maintainence question.
88sasturbotoy
Jan 30, 2026 01:57 PM
kazuya2416
Apr 5, 2024 02:17 AM
young buck
18
Aug 27, 2018 02:40 PM
A2theK
Jan 10, 2016 10:18 AM
andrewtexas123
Jul 14, 2015 04:29 AM
