gears or locker
Gears or Locker?
i am thinking of getting a lock right locker.
but i came across these 4.56 gears from a v6(whole third member just bolt in)
the guy selling them says they will bolt into my 4 cyl diff ,is this true?
if i buy the gears i will eventually get a locker but not for a while.
my truck has a 22r-e with a cam and 35" x-terrains. i often pull a 17 foot boat. i dont need the gears for 4 wheeling but could maybe use them on the street.
locker is $375 cdn
gears are $250 cdn rear
$350 cdn front
locker is $375 cdn
$350 cdn front
gears or locker
i found some gears 4.56 complete with 3rd member for $550 cdn for both (front and rear),they are from a v6 will they fit my 4 cyl.
i can get a locker for my stock 4.10 for $375 cdn
i pull a 17 ft boat sometimes and i also have 35s
i have a 22r-e with a cam
im pretty sure no one is answering right now since you'll find all your answers if you do a search.
personally, if I had a 22re and running 35's with stock gearing, I'd regear, but if I was thinking about putting a locker in the rear, I'd save up for the locker too, then get the locker put in before I put the diff in to save money in the long run.
and to carry the motion I will also say get the lockers. 5.29s are what you want in the diffs. IMO to get 4.56 and still be open will be a waste of money. You would also need to get 4.56 gears installed in the front. Get the locker and save for new gears. that is what I would do.
4.56 isn't enough gear, you want 4.88's or better yet, 5.29's
If it is a daily driver 4.88's might be better because they won't rev as high, but 5.29's will pull harder.
locker is cool for offroad, but for towing you're gonna want a locker that you can turn off, so a 375.00 locker probably ain't gonna be the best choice.
I think its kind of funny how this thread in general tech is solidly for gears yet the one in offroad tech is biased towards the locker...Anyway I say locker or save as the 4.56s will be a waste of money with 35s
4.56 gears with 35's are a waste.
Do you know what gears you have now? If your name is your rig, you may already have them.
If I towed a boat regularly, I would think twice about running a stock geared 4 cylinder on 35's.
Changing diff gears alone makes a very small change in wheeling. Adding t-cases is where it's at.
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
jerusry
Oct 19, 2015 05:28 PM
coffey50
Jul 28, 2015 10:55 AM
