Gearing question
Old Oct 20, 2005 | 10:39 AM
blainelukens's Avatar
Gearing question
Ok so I have an 89 PU V6 5 speed and want to regear it to better acomidate 33x12.5 tires, although I am not sure what to go to, I think that 4.88 would be good? OK so I am very good at working on my truck the only thing is I am not sure what all goes into regearing a diff, if someone could help me out that would be great. Another thing is could I regear the back and not do the front(untill I save up some more $)since I have mannual hubs? any help would be great. Oh yeah about how long does it take to regear the diffs?
Thanks Blaine
Old Oct 20, 2005 | 10:40 AM
Silver_Truck's Avatar
Yes 4.88s would be good...you need the gears and an install kit and I'd have someone do em if you've never done it before
Old Oct 20, 2005 | 10:44 AM
4rnr's Avatar
X2 on 4.88's. And yes you can do the rear and not the front ****IF YOU NEVER SHIFT INTO 4HI OR 4LO***** The insall is EASY but you have to spend time experimenting with shims to get the gears aligned right.
Old Oct 20, 2005 | 11:20 AM
00Runner's Avatar
Even without manual hubs you could regear at different times. Right now I am regearing by swapping diffs. I swapped the rear last weekend and I plan to swap in the front in two weeks. This is fine as long as you never shift into 4WD as 4rnr mentioned.
Old Oct 20, 2005 | 11:29 AM
YeloSub7's Avatar
I have a question to add, is it smart to do it yourself, cause I don't mind spedning the time, I just didn't know if it is something you would do on your own???
Old Oct 20, 2005 | 01:41 PM
ZUK's Avatar
ZUK
Both you guys might want to give it a try....you might get it set up well enough where it will hang in there awhile..or maybe not ....And if it doesn't work out, you could always send it to me for repair. See my webpage. ZUK
XtraCab
Apr 12, 2020 05:25 AM
oldirtydirt
Feb 23, 2020 09:30 AM
mskalmus
May 28, 2017 07:51 AM
coffey50
Jul 28, 2015 10:55 AM
Jnkml
Jul 6, 2015 01:20 PM
