Engine runs fine in park, but stumbles in drive
Old Apr 11, 2012 | 11:06 AM
muddintoyota's Avatar
Hi all, this is my first post here. i'v got a 92 toyota pickup 3.0L made only for the mud. so far iv scrolled threw countless threads but i havnt seen anything with my symptoms! when the truck is in park it will rev up just fine and for the first minute while moving, then it bog down like its starving for fuel . i'v checked the fuel filter and fuel pump and they seem to be working well. any ideas?
Old Apr 11, 2012 | 05:02 PM
Team420's Avatar
Well, I would start with the easy stuff. Is you check engine light on? Have you changed plugs/wires/cap/rotor? If so, compression test? Got good exhaust flow?
Old Apr 11, 2012 | 05:05 PM
StewsRunner's Avatar
I have the same problem, when in reverse or drive (while stopped) the RPMs drop down to about 500 and it shakes something fierce, sounds like it's about to stall. I was thinking maybe the timing. But when in park it idles fine, at about 800
Old Apr 11, 2012 | 05:11 PM
Team420's Avatar
see my post above
Old Apr 11, 2012 | 05:13 PM
I've changed the plugs and wires but the and rotor check out, according to someone other than me, but I'll check that out
Old Apr 11, 2012 | 07:39 PM
No, the check engine light isnt on. As for the plugs and wires the plugs are new the wires are not ill see ig i can get ahold of some tomorrow and see if that makes a difference. Has no problem with exhaust flow its running straight pipes at the moment. Thanks for the quick reply team420!
Yont283
Sep 23, 2022 08:06 PM
zd92655
Mar 6, 2022 12:58 PM
puffin04
Jul 10, 2015 09:17 PM
noahstancik
Jul 10, 2015 11:18 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
