E-Locker Computer Removal
Old Sep 11, 2006 | 01:26 PM
Hyperlite's Avatar
I removed my rear E-locker axle and sold it to a guy that is putting it under a Jeep XJ. He wants the computer and switch and I do not know what to remove w/o making my Runner not work again. Can it be removed and still use the Truck? I think I can safely remove it but I don't know. I tied to search but got nothing. Can some one please explain to me what I need to remove? I know it is under the Drivers kick panel and that's about it.
The Runner is a 97 limited or what's left.
Thanks-
Jon
Old Sep 11, 2006 | 01:33 PM
Bob_98SR5's Avatar
jon,
take a look at phong's old writeup now hosted on sonoran steel's website: http://www.sonoransteel.com/phong/re...ic_locker.html
you will see a link and pics there
bob
Old Sep 14, 2006 | 08:32 AM
00Runner's Avatar
Here is what he needs:
Removing it will have no affect on your 4Runner. 4Runners without the locking diff don't even have this ECU.
Old Sep 20, 2006 | 02:36 PM
Elton's Avatar
sorry to bring up a old thread in that pic is that the blue wire you need to cut to have the locker work any time instead of 4 Lo i tryed it today and all it did was blink
Old Sep 21, 2006 | 06:43 AM
00Runner's Avatar
did you drive around a little bit after engaging the locker? blinking means that it is trying to engage.
Old Sep 21, 2006 | 06:48 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
Originally Posted by Elton
sorry to bring up a old thread in that pic is that the blue wire you need to cut to have the locker work any time instead of 4lo i tryed it today and all it did was blink
blue wire? its called the grey wire mod. here is an excellent writeup. i did it to mine and it worked flawlessly
http://www.customtacos.com/tech/index.php?article=10
Old Sep 21, 2006 | 03:48 PM
Elton's Avatar
tacoma its the gray wire 4runners its the blue/red wire .... and yes i did drive it for a awhile just blinked and it didint work in 4lo
Old Sep 21, 2006 | 07:49 PM
my fault, i thought all were gray. did you ground the correct side?
Old Sep 21, 2006 | 08:03 PM
Elton's Avatar
sorry to hijack this thread but i didint see the point in makin a new thread asking a simple question..... any ways in the write up it said to cut that blue wire in the pic and ground it i did and it dont do anything but blink
Old Sep 21, 2006 | 08:32 PM
did you ground the side coming out of the switch? if youre sure you did, are you sure it has a good connection with the patch wire? what ground did you use? does it have access to bare metal with no paint blocking contact?
Old Oct 25, 2006 | 09:27 PM
sschaefer3's Avatar
Even eaiser way to do it without cutting anything.
http://www.sonoransteel.com/rear_locker.html
Old Oct 25, 2006 | 09:37 PM
Elton's Avatar
thats good but i didint solder mine also a fyi you need to ground the wire going to the box and not to the locker i had to ask since it wasint clear on any writeups
Jun 1, 2021 01:51 PM
pplusent
Sep 18, 2018 10:02 PM
O Holy P
Aug 18, 2015 02:33 PM
Esibnitsud
Jul 30, 2015 08:19 PM
AaronM
Jul 8, 2015 07:15 PM
